Use Inventor Vault Add-in through Inventor API
b.graaf
Message 1 of 23
b.graaf
Is it possible with the Inventor API to:
- check, if the user has logged into Vault (Inventor Vault add-in)
- if not, to open the Vault login screen
- if yes, to use the Inventor Vault add-in
Actually, I am trying to do the following thing:
- I would like to get a list with the files in teh Vault. I would like to get this list through the Inventor API.
Is this possible?
Replies (22)
Message 21 of 23
bradeneuropeArthur
Solved?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 22 of 23
C-Hoppen
@bradeneuropeArthur wrote:
Could you please mark it as solved then!
Thanks again for your help. I can't mark the thread as solved. This can only be done by the thread opener.
Regards
Christoph
Message 23 of 23
MechMachineMan
Expert Elites also have privileges to mark things as solved, given we don't abuse the privilege!
It looks like you did case this one, @bradeneuropeArthur so I have marked this as solved.
Thanks for your contributions!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
