Use Inventor Vault Add-in through Inventor API
b.graaf
Message 1 of 23
b.graaf
Is it possible with the Inventor API to:
- check, if the user has logged into Vault (Inventor Vault add-in)
- if not, to open the Vault login screen
- if yes, to use the Inventor Vault add-in
Actually, I am trying to do the following thing:
- I would like to get a list with the files in teh Vault. I would like to get this list through the Inventor API.
Is this possible?
Replies (22)
Message 2 of 23
smilinger
In your project add references to:
C:\Program Files (x86)\Autodesk\Autodesk Vault 20XX SDK\bin\Autodesk.DataManagement.Client.Framework.Vault.dll
C:\Program Files\Autodesk\Inventor 20XX\Bin\Connectivity.InventorAddin.EdmAddin.dll
In your code:
using Connectivity.InventorAddin.EdmAddin;
using VDF = Autodesk.DataManagement.Client.Framework.Vault;
void DoSomething()
        EdmSecurity edmSecurity = EdmSecurity.Instance;
        VDF.Currency.Connections.Connection connection = edmSecurity.VaultConnection;
        if (edmSecurity.IsSignedIn())
            MessageBox.Show("Vault signed in!");
Message 3 of 23
smilinger
Login with Inventor:
void DoSomething()
        MessageBox.Show("Already signed in!");
    else
        _inventorApplication.CommandManager.ControlDefinitions["LoginCmdIntName"].Execute();
VDF.Currency.Connections.Connection connection = edmSecurity.VaultConnection; if (connection != null) { //...... } }
Message 4 of 23
b.graaf
Tnx, I will give that a try!
Message 5 of 23
wayne.brill
In reply to this:
"I would like to get a list with the files in teh Vault. I would like to get this list through the Inventor API"
You could use the Vault API from an Inventor Add-In to get files in a vault but the Inventor API does not have any methods to access anything in a Vault .
Also:
There is not any API for the Inventor Vault Add-In and the Vault API does not support checking in new assemblies.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 6 of 23
C-Hoppen
the example does not work for me. edmSecurity.IsSignedIn() is always false and edmSecurity.VaultConnection returns null.
I have Inventor 2017 running and I'm connected to a Vault 2018 Prof. Server.
Any ideas why this doesn't work?
Christoph
Message 7 of 23
bradeneuropeArthur
Die uou make the reference to the edmaddin correctly?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 8 of 23
bradeneuropeArthur
Did you make the reference correctly?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 23
C-Hoppen
bradeneurope,
please have a look at my attached vc# project.
What do mean with "referenced correctly"? Any references missing would throw an exception.
Christoph
Message 10 of 23
bradeneuropeArthur
Are you using the vault 2018 api reference?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 23
bradeneuropeArthur
I am not able to take a look at the zip file right now.
Later I will take a look.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 23
C-Hoppen
No, all references are 2017.
Message 13 of 23
bradeneuropeArthur
Thst can be the problem I think. Use the 2018 refs. Or give this I try.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 23
C-Hoppen
I changed all Refs to 2018. No difference. Still no connection.
Christoph
Snippet
using System;
using System.Windows.Forms;
// C:\Program Files\Autodesk\Inventor 2017\Bin\...
// Autodesk.DataManagement.Addin.Framework.dll
// Autodesk.DataManagement.Addin.Vault.dll
// Connectivity.Common.dll
// Connectivity.InventorAddin.EdmAddin.dll
// C:\Program Files (x86)\Autodesk\Autodesk Vault 2017 SDK\bin\x64\Autodesk.DataManagement.Client.Framework.Vault.dll
// C:\Program Files\Autodesk\Inventor 2017\Bin\Public Assemblies\Autodesk.Inventor.Interop.dll
namespace VaultLoginTest
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            try
                Inventor.Application invApp = System.Runtime.InteropServices.Marshal.GetActiveObject
                    ("Inventor.Application")
                    as Inventor.Application;
                if (edmSecurity.IsSignedIn()) // ---------------------- is always false
                else
                    invApp.CommandManager.ControlDefinitions["LoginCmdIntName"].Execute();
                VDF.Currency.Connections.Connection connection = edmSecurity.VaultConnection; // returns always null
            catch (Exception ex)
                MessageBox.Show(ex.Message);
Message 15 of 23
bradeneuropeArthur
You need first to sign in. Using the edm user. Vault. Password. Server etc.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 23
C-Hoppen
I'm logged in to the vault server. I want to use the loggin from Inventors Vault AddIn. It should be done at least by calling
Snippet
else
{ invApp.CommandManager.ControlDefinitions["LoginCmdIntName"].Execute(); }
 which works fine.
But calling edmSecurity.VaultConnection after that returns always null.
I also tried
Snippet
VDF.Currency.Connections.Connection connection = Connectivity.Application.
    VaultBase.ConnectionManager.
           Instance.Connection;
as descriped here:
http://adndevblog.typepad.com/manufacturing/2013/09/autocad-2014-vault-add-in-connection.html
without success - connection is always null.
Christoph
Message 17 of 23
bradeneuropeArthur
I will send you an example what worked by me.
Ok?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 23
bradeneuropeArthur
This is the method to reuse the loggin settings for the vault add-in.
Imports Connectivity.InventorAddin.EdmAddin
	 Public Sub SetupUserInterface(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean, ClientID As String)
			' rest of the code should be left in here for the setupUserInterface
			'to get connection you should use the edmAddin ServerName Vault Name and username with the password you have logged in with.
            If firstTime And...................................................................
Dim strVaulrServerName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.Server Dim strVaultName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.VaultName Dim strVaultUserName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.UserName Dim strVaultPassword As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.Password Dim results As VDF.Vault.Results.LogInResult results = VDF.Vault.Library.ConnectionManager.LogIn(strVaulrServerName, strVaultName, strVaultUserName, strVaultPassword, VDF.Vault.Currency.Connections.AuthenticationFlags.Standard, Nothing) Dim conn As VDF.Vault.Currency.Connections.Connection = Nothing If results.Success Then conn = results.Connection End If end sub
Some time is required to setup the vault connections so it could be possible that the connection was nul because the connection was not ready.
Let me know if it works.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 19 of 23
C-Hoppen
Thanks for your snippet! The magic word was "addInSiteObject"...
I tested all the code snippets in an "stand alone" application which runs out-of-process and that's why all properties were empty.
Now I tested the code in an Inventor AddIn and all snippets are working fine.
Thanks again for help.
Christoph
Message 20 of 23
bradeneuropeArthur
Could you please mark it as solved then!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
