- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I read another post on this topic but I don't believe it is what I am looking for. https://forums.autodesk.com/t5/inventor-customization/supress-if-no-effect/td-p/5612616
I have two cylinders made from a contour flange feature. These two halves make up a complete cylinder and share identical parameters.
Currently I use the cut normal features to put holes in the cylinder using height, degrees, hole size. The parameters are fed from the main assembly so there are multiple cylinders stacked on top of one another. The holes vary in height and some cylinder's will have a hole and others won't. These holes are already modeled in the cylinder and are turned off and on depending on if the equations says the hole is in the range of the cylinders model height.
Because these two cylinders are halves of a hole the hole may only go in one side and not the other. I can make a rule that uses the degrees in an equation for the cylinder half to turn it off and on depending on the input.
After looking around I think it would be much more simpler to just turn the features off and on depending if they have an effect.
This is all being used to make a template that can generate multiple assemblies and models depending on the inputs.
1. How can I turn a feature on and off (cut normal) depending on whether or not it has an effect?
