Supress if no effect
ASchlaack
Message 1 of 22
ASchlaack
Is there a rule to supress a feature (a cut) if it has no effect?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
Replies (21)
Message 2 of 22
MegaJerk
Usually you’ll want to suppress a feature when the conditions of the part do not require it. In other words, what does a user have to do to the part to make the cut unnecessary? Figuring that out will allow you to create a logical statement that turns it off and on based on those conditions.
Additionally, a softer (and while occasionally useful, mostly just extra work and file-size) approach could be to use your sketch containing the profile of your cut to first make a Face Feature, and then reuse it to make the desired cut feature. This will ensure that no matter what, the feature will have something to cut through and will not error out even though it is away from the main body of the part.
To be certain, I have never seen anyone use this method to approach a design (and I’m sure a design guru like JDMathers might have a strong word with me for suggesting that you muck up your model with extra junk), it is a cheap way of working around feature errors in a pinch.
If you need further help, please post some more part specific information.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Message 3 of 22
ASchlaack
That was my first thought to do but this is a complex part that's driven by a few different parameters. And because of them there are times when the sketch losses reference points or ends up erroring itself just to follow the parameters. At the current moment there's about 200 possible models that can be made depending on the varible combinations. So that's why I'd like to have the rule be able to tell when the sketch isn't doing anytihng, if I can't get a rule to do that I'd basically have to write a 200+ case rule that reads a few different parameters.
Aaron Schlaack
Message 4 of 22
mrattray
There is a health status property you could check.
Here is a sample where I check the health status of all of my hole features:
Public Sub findSickFeatures(doc As PartDocument)
Dim hole As HoleFeature
Dim holes As HoleFeatures
holes = doc.ComponentDefinition.Features.HoleFeatures
For Each hole In holes
    If hole.HealthStatus <> kUpToDateHealth And hole.HealthStatus <> kSuppressedHealth Then
        MsgBox("There's a problem with one of the hole patterns. Check your parameters. Problem feature: " & hole.Name, vbOKOnly, "UnHealthy Feature Detected!")
        Exit Sub
Next
End Sub
Mike (not Matt) Rattray
Message 5 of 22
ASchlaack
That's really cool, thanks. But what would you use to replace "hole" and "HoleFeature" on the second line? I tried just doing "Cut" and "CutFeature" but that didn't work.
Aaron Schlaack
Message 6 of 22
ASchlaack
Aaron Schlaack
Message 7 of 22
MechMachineMan
Still rocking the For loop in terms of holes.
And also, don't you mean extrusion rather than cut?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 8 of 22
ASchlaack
No, it's sheet metal so it's a cut.
Aaron Schlaack
Message 9 of 22
MegaJerk
Interesting. Is there any chance that you could post the part proper (or a run-down version of it)?
GitHub
Message 10 of 22
ASchlaack
Here's about what the part is. There's a form you can open, change that (or the parameter named "Angle) to 0. Then there will be the cut error. I've also got the rule given above but it doesn't work due to the errors it's getting, also talked about above.
Aaron Schlaack
Message 11 of 22
MegaJerk
I finally found some time to look at your part and have re-uploaded it here for you check. Instead of trying to suppress a feature that was in an error state, I instead used a mathematical / logical approach to solving the problem. In fact, here is the code that I used :
If Angle < 0 Then
	Angle = 0
If Angle > 90 Then
	Angle = 90
Feature.IsActive("Cut1") = Angle > 0 And Angle < 90
What's happening there?
Well first and foremost, I am setting up a minimum and maximum distance that your angle can be. Why? Because going beyond 90 degrees will result in your part being cut into two separate bodies (ew), and everything from 180 ~ 360 (or everything below 0 to -180) is totally unaffected by the cut feature any ways. There's no reason we should let the user input values outside of the 0~90 range, but making a giant table of acceptable ranges is... well... unacceptable. The first two IF/THEN statements keeps our ranges in check.
The LAST line of code is what turns the feature on / off, but we're being a bit clever about it. Instead of writing an IF/THEN statement, I'm basically saying that the Feature's State will = The outcome of the conditional statement 'Angle > 0 And Angle < 90'  That means that the Feature.IsActive("Cut1") is only true if Angle is Above 0 AND Below 90. If one of those conditions is isn't true (for instance, your angle is 0) then the cut is turned off.
Here is another way I could have written that
If Angle > 0 Then
   If Angle < 90 Then
      Feature.IsActive("Cut1") = True
    Else
      Feature.IsActive("Cut1") = False
Else
Pretty big difference huh?
Now, while I understand that your real-world part may be a lot more complicated than the one you gave me, I highly recommend that you do not give up on approaching this from the same vector I did. Just as you would model a part or assembly with your design intent in mind, you often can use those same constraints to logically configure and manipulate the more dynamic aspects of those same models.
If you like how simply this problem was solved, but are unsure whether or not you can apply that same simplicity to a more complicated feature set, please do post more things (or through private message), and I will do my best to find a less API heavy way of solving it.
TOTAL SIDE NOTE: When in the hell did Inventor get good at not freaking out when you drove a dimension below 0 using a parameter (or some other math)!? Granted, if you try to open a dim that is below 0, it will still say that it's out of an expected range, but it used to just be a 50:50 chance as to which direction it would go once you increased the value > 0.
Crazy stuff!
**** EDIT ****
Never mind 😞 Further tests show that while it works on the instance of this part (and possibly angles in general), it does not however work for linear dimensions in an expected way 😞 I guess I'll stick to using work geometry offsets as a deterrent. **** it!!!
- The End
GitHub
Message 12 of 22
ASchlaack
I get what you're saying and thanks for the help! I guess I'm just going to have to do it the long way and figure out every situation and have it turn on or off by case statement.
Aaron Schlaack
Message 13 of 22
ASchlaack
Mike,
Could I please get you to edit this to be for extrusions or cuts please? I'm not skilled enough to do this on my own, I've put in a few attempts but nothing seems to work.
Aaron Schlaack
Message 14 of 22
MegaJerk
Like I said, if you need help with making it as simplistic as possible, post your part here and we can work on it.
GitHub
Message 15 of 22
ASchlaack
Due to the nature of what it is I can't post or share my part. The best I can honestly post is the part I already did.
Aaron Schlaack
Message 16 of 22
philippe.leefsma
It is a CutFeature, see how easily I can find this out using the VBA editor:
http://screencast.com/t/q8yTveaKQrv
And the reply using the health status is the correct way to check if a feature has an effect or not.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Message 17 of 22
ASchlaack
I'm very confued by the link to a screenshot you posted.. What's it showing?
Aaron Schlaack
Message 18 of 22
philippe.leefsma
Sorry I posted a scrennshot instead of the recording :s
Here you go:
http://screencast.com/t/aQN0osPa2Cr
It shows how to use VBA and the select set to check what object type in the API represents the selected entity in the UI.
Hope that helps,
Philippe.
Philippe Leefsma
Message 19 of 22
rjay75
Shot gun approach to just check all features.
Dim feature As PartFeature
Dim features As Features
features = doc.ComponentDefinition.Features
For Each feature In features
    If feature.HealthStatus <> kUpToDateHealth And feature.HealthStatus <> kSuppressedHealth Then
        MsgBox("There's a problem with one of the features. Check your parameters. Problem feature: " & feature.Name, vbOKOnly, "UnHealthy Feature Detected!")
        Exit Sub
Next
End Sub
If you really only want cuts and extrusions
features = doc.SheetMetalComponentDefinition.Features
    If (TypeOf feature Is CutFeature Or TypeOf feature Is ExtrudeFeature) And feature.HealthStatus <> kUpToDateHealth And feature.HealthStatus <> kSuppressedHealth Then
        Exit Sub
Next
End Sub
Message 20 of 22
ASchlaack
But if something else errors out then it will change what I only what it to if the one feature errors out. Is there anyway I can just do it for "extrusion3"?
Aaron Schlaack
