CreateFileDialog not working in 2019
DWhiteley
Advisor Advisor
Message 1 of 11
DWhiteley
This code works fine in 2018 but not in 2019 (build 136)
' Create a new FileDialog object.
Dim oFileDlg As Inventor.FileDialog
Call Me.m_inventorApplication.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Drawing Files (*.idw;*.dwg)| *.idw;*.dwg"
oFileDlg.FilterIndex = 1
oFileDlg.DialogTitle = "Select drawing template"
oFileDlg.InitialDirectory = oTLoc
oFileDlg.InsertMode = False
oFileDlg.MultiSelectEnabled = False
oFileDlg.SuppressResolutionWarnings = True
oFileDlg.CancelError = False
oFileDlg.ShowOpen()
The dialog box opens, I can select a file (in this case DWG or IDW), but when you click on OPEN nothing happens.
Dave
Envisage
Replies (10)
Message 2 of 11
MechMachineMan
Where is the rest of the code?
CreateFileDialog is simply a function that shows a form and RETURNS a file name as string, it does not do any operations with the selected file.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 11
DWhiteley
Correct, but in 2019 the ‘open’ button does nothing.
Message 4 of 11
DWhiteley
Btw the code this is used in has worked fine from release 2014-2018. It fails in 2019 with the open button being inactive and hence returning no file name. Only cancel works.
Message 5 of 11
MechMachineMan
And as in 'nothing' you mean as in it's like you didn't even click it?
It doesn't even close the dialog by pressing open?
Justin K
Message 6 of 11
bradeneuropeArthur
try this:
Public Sub dd()
Call ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.ShowOpen
Dim a As Document
Set a = ThisApplication.Documents.Open(oFileDlg.FileName, True)
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 7 of 11
DWhiteley
Very funny! Yes of course, I did click it but nothing happens.
Message 8 of 11
MechMachineMan
Sounds like a bug for our Autodesk employee friends to investigate then.
(I'm not on 2019 yet or else I would try investigating further myself)
@chandra.shekar.g or @johnsonshiue
Justin K
Message 9 of 11
bradeneuropeArthur
Does this have any influence:
https://msdn.microsoft.com/en-us/library/system.windows.forms.filedialog.options(v=vs.110).aspx
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 11
DWhiteley
I now have this working, by using an earlier version of the inventor.interop
(OPEN button not responsive in .showopen)
Dave
Envisage
Message 11 of 11
chandra.shekar.g
Autodesk Support
Autodesk Support
@DWhiteley,
Could please demonstrate working of open dialog in Inventor 2018 with a sample screencast or video record?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
