Sorting excel range through iLogic
Message 1 of 8
Hello everyone,
How can I sort a range in Excel through iLogic?
When I try the following code:
Sub Main()
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oBOM As BOM = oDoc.ComponentDefinition.BOM
	Dim objExcel = CreateObject("Excel.Application")
	ThisBOM.Export("Parts Only", "C:\Users\ben.wouters\Desktop\TEST.xlsx", kMicrosoftExcelFormat)
	Dim objWorkbook = objExcel.Workbooks.Open("C:\Users\ben.wouters\Desktop\TEST.xlsx")
	excelSheet = objWorkbook.Worksheets(1)
	objExcel.Columns.AutoFit
	excelSheet.Range("A1:I16").Sort(Key1:=excelSheet.Range("C1"), Order1:=xlAscending, Header:=xlYes)
	objExcel.Application.Visible = True
End Sub
I get an error message saying "Method Sort of class Range has failed".
However when I run the rule with the sort line commented out, it runs just fine. It just doesn't get sorted.
I'v tried a bunch of stuff, but either it throws up the error message above or I get the following: "Exception from HRESULT: 0x800A03EC".
Any help would be greatly appreciated.
Replies (7)
Message 2 of 8
bradeneuropeArthur
Sub Main()
	excelSheet.Worksheets("Sheet1").Sort.SortFields.Add Key:=Range("A1:I16"), _
        SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
Hey Arthur,
Thanks for your reply. Your code doesn't work for me.
Let me start by mentioning that I'm working with Inventor Professional 2016.
When I copy and paste your code, it doesn't run saying that Methodarguments must be between brackets and that Range isn't declared.
So I tried the following:
	excelSheet.Worksheets("Sheet1").Sort.SortFields.Add (Key:=excelSheet.Range("A1:I16"), _
    SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal)
But that gives me the error that public member Worksheets for type Worksheet wasn't found.
Replacing the word excelSheet with objWorkbook gives me the error: Exception from HRESULT: 0x800A03EC.
Message 4 of 8
bradeneuropeArthur
Try this:
excelSheet.Worksheets("Sheet1").Sort.SortFields.Add (Key:=excelSheet.Range("A1:A16"), _
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
Hey Arthur,
I get the public member Worksheets for type Worksheet wasn't found error again.
Message 6 of 8
bradeneuropeArthur
maybe this will help you:
https://stackoverflow.com/questions/21451458/vba-excel-sort-range-by-specific-column
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
Hey Arthur,
Thanks for the help. I managed to do what I wanted to do by using the FindRow snippet in Inventors iLogic editor.
Message 8 of 8
Peterjan.Schakel
Hello Wouteb,
I am currently traying the same thing, Sorting data of excel trough iLogic. I have tried every code described above, with no positive outcome (no error, just nothing happens). Is it possible that you share the code you used?
greets,
Peterjan Schakel
