iLogic - External Rule not found?
GKPByDesign
GKPByDesign
I have created some rules and they were working fine, but now it is staying that it cannot find certain external rules, even though they are in the exact place, is this normal for external rules? I am new to external rules, and wonder if its a behaviour of using them ?
GKPByDesign
Fixed it, I have an iLogic folder in which I have further sub folders. This was causing the issue as I had only set up iLogic configuration to look for the top folder, adding the sub folder separately to this solved the issue.
User-added image
AlexFielder
This could probably be logged as an idea: "Allow iLogic External Rules to look in subfolders" and would be a simple checkbox on the dialogue you showed above.
chandra.shekar.g
Autodesk Support
Autodesk Support
@GKPByDesign,
It seems to be limitation of Inventor. Please log a wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
