ON/Off Origin planes
Message 1 of 14
For constraining parts in an assembly I use a lot the origin planes of the parts. When switching on/off the visibility of the origin planes in the assembly (object visibility).
I only see the origin planes of the parts which have switch on  the visibility of the origin planes in the party itself. Unfortyunally, some are set to visilble other are not...
Is there a way to switch on/off all the origin planes of the parts themselves, so I can easely switch on/off their visibility on the assembly with ?
Replies (13)
Message 2 of 14
bradeneuropeArthur
The only way to do that is to manually set the workplanes visible in the parts.
The method "object visibility" only works for the visible features in the models themselves. The visibility is handled in the assembly and not in the part. This means the "object visibility"  only works if you change the part.
If you need that you need to loop through the assembly occurences and set the workplanes visible or invisible.
Do you need that?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 14
johan.degreef
yes
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Message 4 of 14
bradeneuropeArthur
what features need to be set visible?
only origin workplanes?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 14
Yes, switching on/off only the origin workplanes of all underlying parts and subassemblies by running the rule, if possible..
Message 6 of 14
bradeneuropeArthur
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As AssemblyDocument
Set b = a.ActiveDocument
Dim c As AssemblyComponentDefinition
Set c = b.ComponentDefinition
Dim occ As ComponentOccurrence
For Each occ In c.Occurrences
Dim d As Document
Set d = occ.Definition.Document
'MsgBox d.ComponentDefinition.WorkPlanes.Item("XY Plane").Name
d.ComponentDefinition.WorkPlanes.Item("YZ Plane").Visible = True
d.ComponentDefinition.WorkPlanes.Item("XZ Plane").Visible = True
d.ComponentDefinition.WorkPlanes.Item("XY Plane").Visible = True
'occ.Definition.Document
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 14
Sergio.D.Suárez
If it has a very large assembly and activates the visibility of all the main planes of origin, it can be complicated to work on the components because many planes will appear activated. With this external ilogic rule, you will select the components in which you need to activate / deactivate the planes, with the escape key you will exit the loop.
Dim comps As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
While True
Dim comp As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a component")
If IsNothing(comp) Then Exit While
comps.Add(comp)
End While
For Each comp In comps
	Dim WP As WorkPlane = comp.definition.document.ComponentDefinition.WorkPlanes.Item(1)
	Dim oValue As Boolean
	If WP.Visible = True Then oValue = False Else oValue = True
	For i As Integer = 1 To 3
		comp.definition.document.ComponentDefinition.WorkPlanes.Item(i).Visible = oValue
	Next
	iLogicVb.UpdateWhenDone = True
Next
 I hope it will be useful. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 8 of 14
It is a good idea, this is a great piece of code!
Message 9 of 14
j_weber
Great code.
Perheps you can put the ESC Command in the Kontextmenu when the code works
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
Message 10 of 14
JBerns
@Sergio.D.Suárez,
Your code will be very helpful!
One question: instead of pressing ESC to exit the loop, could the code be changed to loop until ENTER is pressed?
Our designers come from an AutoCAD background, so ESC usually cancels a command without changing anything, while ENTER ends the command and accepts all input. I have searched the forums and other sites, but have only found code for using the ESC key.
Thanks for your time. I look forward to the replies.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 11 of 14
m_send
Community Visitor
Community Visitor
Dear Sergio.D.Suárez
Tanks for this nice Code. It's very helpful.
Unfortunately i get an error when i try using it on content center files/ custom content center files like elbow fitting.
Do you have maybe an idea whaht's the problem?
System.Runtime.InteropServices.COMException (0x80004005): Unbekannter Fehler (Ausnahme von HRESULT: 0x80004005 (E_FAIL))
bei Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateSet(Object o, Type& objType, String name, Object[] args, String[] paramnames, Boolean OptimisticSet, CallType UseCallType)
bei Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateSet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean OptimisticSet, Boolean RValueBase, CallType CallType)
bei Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateSetComplex(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean OptimisticSet, Boolean RValueBase)
bei ThisRule.Main() in Externe Regel: Ursprungsebenen anzeigen:Zeile 22.
bei Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
bei iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Best Regards
Michael
Message 12 of 14
WCrihfield
Hi @m_send.  It is most likely encountering the errors because content center files are ReadOnly.  There are a few ways around this issue.  One way to avoid those potential errors is to enclose the lines of code that are trying to make changes to change the visibility of the WorkPlanes within the Try side of a Try...Catch statement.  When you do that, if it fails, it will not throw an error that will stop the rule.  Instead it will simply continue on to whatever is next in the code.  You can also place some code within the Catch side of that statement that will try to do something when the code in the Try side fails.  This is often used as a debug tool by including some feedback on the Catch side, like a message or an iLogic Log entry with the Logger.Error() snippet.  Another way to avoid those errors is to filter out any components that represent content center parts.  That way they do not get processed.  Checking if a component represents a content center part is not the simplest process, because the ComponentOccurrence object does not have a direct property for that.  Only the PartComponentDefinition has a property for that (PartComponentDefinition.IsContentMember).  The ComponentOccurrence.Definition property returns its ComponentDefinition, but you can only access that if the component is not currently suppressed.  If you try to access that while it is suppressed, it will throw an error.  Once you have the ComponentDefinition, you must first make sure it is specifically a PartComponentDefinition (as sub type), and not an AssemblyComponentDefinition (or one of the other sub types).  Then you can check that property's value.
Wesley Crihfield
(Not an Autodesk Employee)
Message 13 of 14
m_send
Community Visitor
Community Visitor
Thank you very much for your reply!
Unfortunately i am not good in programming and only use some iLogic rues i find to improve my work performance...
I would like to add this Try....Catch Statement but i dont know in which line and what it should include to solve this problem. I would be very happy if you could help me..
It find always a fault in rule line 15 and says for conent center files:
here Ausnahme = Exception
Thanks in advance
Message 14 of 14
WCrihfield
Hi @m_send.  Here is a very similar example you can try, in which it incorporates a couple of those Try...Catch statements to help avoid potential errors.  In this example, instead of using an ObjectCollection and a 'While' loop, it is using the old 'GoTo' keyword.  But in both examples, you can just use your 'Esc' keyboard key when it asks you to select a component, which will let the code resume without anything being selected, and when nothing has been selected, that will cause it to exit the loop.  It is using a Try...Catch statement where it attempts to access the WorkPlanes collection of the component, because accessing the 'Definition' property of a component that is currently suppressed will throw an error.  You may never select a suppressed component, but if you do, it will avoid that error, and just exit the routine.  Then this example, the line of code that attempts to change the visibility of a WorkPlane is enclosed within a Try...Catch statement, to avoid that potential error, because that will fail if the document the component references is ReadOnly, like content center files and such.  The 'GoTo' term just tells the rule to go to where the following term is found, which in this case is just before the line of code for picking another component.  You could also ask the user a simple question at that point, like "Go again?", and then only loop again if they answer Yes.  I have used that technique many times before to avoid endless loops in basic code routines.  It just involves an extra mouse click each time to continue.
Dim oOcc As ComponentOccurrence, oWPlanes As WorkPlanes, oWPlane As WorkPlane
Dim sPrompt As String = "Select a component." & vbCrLf & "Or tap ESC key to exit loop."
PickAgain :
oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, sPrompt)
If oOcc Is Nothing Then Return
Try 'this will fail if the component is suppressed, also maybe if it is a virtual component
	oWPlanes = oOcc.Definition.WorkPlanes
Catch
	Return 'exit this routine, because it could not access the WorkPlanes
End Try
For Each oWPlane In oWPlanes
	If oWPlane.IsCoordinateSystemElement Then
		If oWPlane.Visible = True Then
			Try 'this will fail if the referenced document is ReadOnly (content center, library, etc)
				oWPlane.Visible = False
			Catch
				'what to do if it fails here
			End Try
Next
'If MsgBox("Pick again?", vbYesNo+vbQuestion, "Again?") = vbNo Then Return
GoTo PickAgain 'go to where this term is found
Wesley Crihfield
