Supress folders & sub assembly folders named Reference - not declared warning
andrew_canfield
andrew_canfield
Hello
I've found this which will suppress top level folders:
https://adndevblog.typepad.com/manufacturing/2015/05/suppress-folder-in-assembly.html
then this to iterate an assembly:
https://modthemachine.typepad.com/my_weblog/assemblies/page/2/
I  copied this into Visual Studio to clear warnings (think it was VBA)
 but see this in iLogic:
the next step would be to run ilogic rule 1 when the iterate finds an assembly?
The aim is to supress an entire tree of folders & sub assembly folders named 'Reference' - may there's another way?
Regards
Andrew
JamieVJohnson2
You have Sub Main, and then TraverseAssemblySample, you took the code of TraverseAssemblySample (including its title) and put it within Sub Main, causing a situation where you have 2 definitions and only 1 ending.  Simply fix by deleting the line TraversAssemblySample.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
andrew_canfield
I should of used different terminology..
this fixes the problem
https://forums.autodesk.com/t5/inventor-customization/ilogic-to-control-lod-in-sub-assemblies/td-p/6...
andrew_canfield
I'm trying to merge two rules
Set the LOD on each level
Suppress a folder
Both work  but i'd like to suppress the folder on each level:
Folder named 'Reference' is supressed:
Sub Main()
  Dim oDoc As AssemblyDocument
  oDoc = ThisApplication.ActiveDocument
  Dim oPane As BrowserPane
  oPane = oDoc.BrowserPanes("Model")
  Dim oTopNode As BrowserNode
  oTopNode = oPane.TopNode
  Dim oFolder As BrowserFolder
  oFolder = oTopNode.BrowserFolders.Item("Reference")
  Call SuppressFolder(oFolder)
End Sub
' Recursive function as there could be subfolders too
Sub SuppressFolder(oFolder As BrowserFolder)
  Dim oItem As BrowserNode
  For Each oItem In oFolder.BrowserNode.BrowserNodes
    Dim oObj As Object
    oObj = oItem.NativeObject
    If TypeOf oObj Is BrowserFolder Then
      Call SuppressFolder(oObj)
    ElseIf TypeOf oObj Is ComponentOccurrence Then
      Dim oOcc As ComponentOccurrence
      oOcc = oObj
      If Not oOcc.Suppressed Then Call oOcc.Suppress
    ElseIf TypeOf oObj Is OccurrencePattern Then
      Dim oPatt As OccurrencePattern
      oPatt = oObj
      Dim oElem As OccurrencePatternElement
      For Each oElem In oPatt.OccurrencePatternElements
        For Each oOcc In oElem.Occurrences
        Next
      Next
  Next
End Sub
all levels are set to 'Simple without ref'
Sub Main()
    Dim oDoc As Document
    oDoc = ThisDoc.Document
    Dim oAssyDoc As AssemblyDocument
    oAssyDoc = TryCast(oDoc, AssemblyDocument)
    If oAssyDoc Is Nothing Then
        MessageBox.Show("Document not of Assembly Type")
        Exit Sub
    Try
		oAssyDoc.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("Simple without REF").Activate
	Catch
		MessageBox.Show("Unable to find 'Simple without REF' LOD on " & oAssyDoc.DisplayName)
	End Try
	Dim oOccs As ComponentOccurrences
	oOccs = oAssyDoc.ComponentDefinition.Occurrences
	For Each oOcc As ComponentOccurrence In oOccs
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject
			'MessageBox.Show(oOcc.Name)
			iLogicVb.RunRule("Rule3")
			Try
				oOcc.SetLevelOfDetailRepresentation("Simple without REF")
			Catch
				MessageBox.Show("Unable to find 'Simple without REF' LOD on " & oOcc.Name)
			End Try
	Next
End Sub
Merging the two:
No errors but the folder isn't suppressed either.
Sub Main()
        Exit Sub
    Try
	Catch
	End Try
			Try
			Catch
			End Try
	Next
End Sub
  'Dim oItem As BrowserNode
    'Dim oFolder As BrowserFolder
  'oFolder = oTopNode.BrowserFolders.Item("Reference")
    Dim oObj As Object
      oOcc = oObj
      oPatt = oObj
        Next
      Next
	MessageBox.Show("76", "Title")
  Next
End Sub
i'll keep trying.
Regards
Andrew
andrew_canfield
saved the assembly & it appears to work - always happens after posting!
nope - spoke too soon
the lower lever folders will not supress the contents..
