Sheet Metal Extents (Size_Thickness, Size_Width and Size_Length) for BOM
RoyWickrama_RWEI
Advisor Advisor
RoyWickrama_RWEI
Sheet Metal:
Thickness (T)
Width (W)
Length (L)
Can I get Thickness, Width and Length in BOM with an iLogic rule. with these parameters not created in PARAMETERS table
Thanks a lot for helping.
bradeneuropeArthur
You can configure the Partslist style with the needed parameters!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
rhasell
Hi
I cobbled together a rule for you to look at.
This will create the Parameters and then populate them with the Sheetmetal Extents.
I will leave the BOM formatting up to you.
Note this will not update dynamically, you need additional steps for that.
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim userParams As UserParameters = oPartDoc.ComponentDefinition.Parameters.UserParameters
Dim newParam As UserParameter ' Placeholder
Dim oFormat As CustomPropertyFormat
'LENGTH
Try
	oParam = oPartDoc.ComponentDefinition.Parameters("LENGTH")
Catch 	'If the parameter was not found, then create a new one.
	newParam = userParams.AddByExpression("LENGTH", 0, "mm") ' Create the Parameter as per above
	newParam.ExposedAsProperty = True 'Flag for Export
	oFormat = newParam.CustomPropertyFormat 'For some reason or other this line is needed to enable the following formatting
	oFormat.PropertyType = Inventor.CustomPropertyTypeEnum.kTextPropertyType
	oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision 'Set one decimal place
	'oFormat.Units="mm" 'Units
	oFormat.ShowUnitsString = False
	oFormat.ShowLeadingZeros = False
	oFormat.ShowTrailingZeros = False
End Try
'WIDTH
Try
	oParam = oPartDoc.ComponentDefinition.Parameters("WIDTH")
	newParam = userParams.AddByExpression("WIDTH", 0, "mm") ' Create the Parameter as per above
End Try
'THICK
Try
	oParam = oPartDoc.ComponentDefinition.Parameters("THICK")
	newParam = userParams.AddByExpression("THICK", 0, "mm") ' Create the Parameter as per above
End Try
Dim oPart As PartDocument
oPart = ThisApplication.ActiveDocument
oDoc = ThisApplication.ActiveDocument
'Turn off work features so they don't calculate
oPart.ObjectVisibility.AllWorkFeatures = False
InventorVb.DocumentUpdate()
Dim sizes As New List(Of Double)
sizes.Add(SheetMetal.FlatExtentsLength)
sizes.Add(SheetMetal.FlatExtentsWidth)
sizes.Sort()
Parameter("LENGTH") = sizes(1)
Parameter("WIDTH") = sizes(0)
Parameter("THICK") = "Thickness"
iLogicVb.UpdateWhenDone = True
'Turn back on work features - optional
oPart.ObjectVisibility.AllWorkFeatures = True
Reg
2026.1
RoyWickrama_RWEI
Thanks for the reply.
I will explore, May be I will get it through.
