Export to dxf without tangent and bending line
kresh.bell
Message 1 of 8
kresh.bell
this is a great iLogic for me to export to dxf. Is it possible to edit it in such a way that dxf geometry has no tangent line and bending line?
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
	Return
	Else
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
'- - - - - - - - - - - - -Component  - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
		For Each oRefDoc In oRefDocs
			iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
    		'check that model is saved
			If(System.IO.File.Exists(iptPathName)) Then
                Dim oDrawDoc As PartDocument
                oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
            	oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
				Try
                	'Set the DXF target file name
                	oDataMedium.FileName = oFolder & "\" & oFileName & ".dxf"
					Dim oCompDef As SheetMetalComponentDefinition
					oCompDef = oDrawDoc.ComponentDefinition
					If oCompDef.HasFlatPattern = False Then
						oCompDef.Unfold
					Else
   						oCompDef.FlatPattern.Edit
					Dim sOut As String
					sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
					oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
					'just for check its works coretcly
					'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
					'MessageBox.Show(i,"title",MessageBoxButtons.OK)
					'If i=2 Then
						'Exit Sub
					'End If
					oCompDef.FlatPattern.ExitEdit
				Catch
				End Try
				oDrawDoc.Close
			Else
		Next
thanks
Kresh
Replies (7)
Message 2 of 8
Sergio.D.Suárez
Hello, try this ilogic code from assembly.
This file will look for parts that are made of metal sheet in your assembly.
Create a temporary drawing file without TitleBlock and place a view of the displayed sheet in 1: 1 scale
You will see the tangent lines of fold, then save as dwg and finally close the temporary file.
Dim openDoc As AssemblyDocument = ThisDoc.Document
InventorVb.DocumentUpdate()
For Each oDoc As Document In openDoc.AllReferencedDocuments
	If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Dim oPath As String = oDoc.FullFileName
		Dim oFileName As String = Left(oPath, (InStrRev(oPath, ".", -1, vbTextCompare) - 1))
		Dim oDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
		If oDef.HasFlatPattern = False Then
			oDef.Unfold
			oDef.FlatPattern.ExitEdit
			oDoc.Close
		Dim oBaseViewOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap ' Create a new NameValueMap object
		oBaseViewOptions.Add("SheetMetalFoldedModel", False) 'True = folded view False = flat pattern view
		Dim oDrawDoc As Inventor.DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,Nothing,True)'False
		Dim oPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)' view insert point
		Dim oView As DrawingView = oDrawDoc.Sheets.Item(1).DrawingViews.AddBaseView(oDoc, oPoint1, 1, _
		ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle,,, oBaseViewOptions)
		oView.DisplayBendExtents = True
		oDrawDoc.SaveAs(oFileName & ".dwg", True)
		oDrawDoc.Close(True)
Next
 I hope this is useful for your task. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 8
kresh.bell
Again there is a bend line and tangent line, and save as dwg, not dxf. My nesting software automatically imports dxf files and confuses it with band line and tangnet line
Message 4 of 8
Sergio.D.Suárez
	 On Error Resume Next
		ThisApplication.Documents.Open(oDoc.FullFileName, True)
		Dim oFilename As String = Left(oDoc.FullFileName, (InStrRev(oDoc.FullFileName, ".", -1, vbTextCompare) - 1))  &  ".dxf"
		Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
			oCompDef.Unfold
		Else
		Dim oFlatPattern As FlatPattern = oCompDef.FlatPattern
		Dim oFace As Face = oFlatPattern.TopFace
		Dim oCommand As CommandManager = ThisApplication.CommandManager
		oCommand.DoSelect(oFace)
		oCommand.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,oFilename)
		oCommand.ControlDefinitions.Item("GeomToDXFCommand").Execute2(True)
		oDoc.Close
Next
 I'm sorry, I've understood you the other way around.
Try this code from an assembly.
It will take all the reference components that are of sheet metal and will export its flatpattern to dxf, without folding lines and without tangent lines.
I hope it is useful for you. regards
Mechanical Designer
Message 5 of 8
kresh.bell
really great, tnx
Message 6 of 8
Rusty.Kight
First of all, thank you for this code!  It works really well.  Here's my problem:
The parts in my assembly have very generic filenames.  Each part has a parameter named "Job" where the top level pushes a job number to.  Each part also has a suffix parameter.  From there (using iLogic in each part), I build a part number iprop specific to the job going through our high volume, custom fabrication shop.
I would like to name the dxf's files specific to either the part parameters i've mentioned, or possibly the part number iprop, if possible.  I've had trouble "getting at" these parameters or iprops from this code in the top assembly level.  Any ideas on how to do that?  Thanks again!
Message 7 of 8
nicolamora
Wow, you code is great!! Well done.
Is it possible to change the location of the DXF files in c:\temp
Message 8 of 8
radcamftp
Community Visitor
Community Visitor
Hi, Thank you this code works. but I need slight modifications to this. how to save these drawings in a folder where the assembly file is located?
