How to Balloon Move and/or Align
bradeneuropeArthur
Mentor Mentor
Message 1 of 9
bradeneuropeArthur
How can I move/reposition/align a drawing balloon with either vba/vb.net/I-logic?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Accepted solutions (3)
Replies (8)
Message 2 of 9
bradeneuropeArthur
Hi,@Sergio.D.Suárez
Maybe you have an idea for this!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 3 of 9
Sergio.D.Suárez
Hello! try to take a sheet, place a view and add a ballon. Then it is necessary to create an access to its coordinates and it worked. The problem that I can not reposition to another place with code, try to match the corrected ones and do not perform any action, I keep trying and trying. regards
Dim doc = ThisDoc.Document
coordX = Round(doc.Activesheet.Balloons(1).Position.X,3)
coordY = Round(doc.Activesheet.Balloons(1).Position.Y,3)
MessageBox.Show(coordX & " | " & coordY )
Dim oPlacementPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(2,2)
'doc.Activesheet.Balloons(1).Position = oPlacementPoint
doc.Activesheet.Balloons(1).Position.X = oPlacementPoint.X
doc.Activesheet.Balloons(1).Position.Y = oPlacementPoint.Y
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 4 of 9
bradeneuropeArthur
Hi @Sergio.D.Suárez
That seems to be also my problem.
Repositioning with "putpointdata" does not work....
Thanks anyway!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 9
bradeneuropeArthur
Found it after removed the uncommented...
Public Sub main()
Dim doc As DrawingDocument
Set doc = ThisApplication.ActiveDocument '.Document
coordX = Round(doc.ActiveSheet.Balloons(1).Position.X, 3)
coordY = Round(doc.ActiveSheet.Balloons(1).Position.Y, 3)
MsgBox (coordX & " | " & coordY)
Set oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(2, 2)
doc.ActiveSheet.Balloons(1).Position = oPlacementPoint
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 9
Sergio.D.Suárez
I imagined it, it must be an ilogic bug, in ilogic 2018 it does not work, or maybe you have to add a header at the beginning to make it work.
I'm glad that as always you reach the solution! Best Regards!
Mechanical Designer
Message 7 of 9
bradeneuropeArthur
Hi, @Sergio.D.Suárez
Thank you also as usual.
You really put me in the right direction, so actual you solved it.
Thanks for supporting in the forum.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 9
bradeneuropeArthur
Also the I-logic code works fine with some modification!
Dim doc As DrawingDocument = ThisDoc.Document
Dim oPlacementPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(20,20)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 9
Hi, With very little knowledge  and with above reference of code,  I tweak code a bit and managed to move my balloons in horizontal, Vertical and in Diagonal direction
But, I want  my Balloons placed "AROUND" can somebody help me go in right direction.
here is my ilogic code with reference to above post:
Dim n1 As Integer = 0
Dim n2 As Integer = 0
n1+= 10
n2+= 10
Dim i As Integer
For i = 1 To 28
coordX = Round(doc.ActiveSheet.Balloons(i).Position.X,n1)
coordY = Round(doc.ActiveSheet.Balloons(i).Position.Y,n1)
'MessageBox.Show(coordX & " | " & coordY )
'Dim oPlacementPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(20, ActiveSheet.View("VIEW2").View.Top)
Dim oPlacementPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(n1+i,ActiveSheet.View("VIEW2").View.Top)
doc.ActiveSheet.Balloons(i).Position = oPlacementPoint
Next
Regards
Hameed
