Self updating AddIn
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
I made an AddIn that is actively used at my company. And by actively I mean by the users and the developer (me), so there are frequent updates for the AddIn holding new features and bug fixes.
Currently when a new version goes live, a Email is sent to ALL of the end-users that they need to run the installer to get the latest .dll file on their computer.
To avoid that someone forgets or ignores the email I would like to compare the AddIn .dll files the local one stored under
C:\Program Files\Autodesk\Inventor 2014\Bin
And the one on the network drive ( or maybe in the future, on the FTP server ). I did some research and found a way to do this check.
Dim myFileVersionInfo As FileVersionInfo
myFileVersionInfo = FileVersionInfo.GetVersionInfo("C:\Program Files\Autodesk\Inventor 2014\Bin\xxxx.dll")
Dim serverFileVersionInfo As FileVersionInfo
serverFileVersionInfo = FileVersionInfo.GetVersionInfo("T:\Inventor\Tools\xxxxx\xxxxx.dll")
Debug.Print(String.Compare(myFileVersionInfo.ProductVersion, serverFileVersionInfo.ProductVersion))
When this result = -1 the local file is out of date and the .dll file should be replaced. Problem is.. When Inventor is running the .dll file cannot be replaced. How should I handle this?
My check is currently situated in the activate sub
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
' This method is called by Inventor when it loads the AddIn.
' The AddInSiteObject provides access to the Inventor Application object.
' The FirstTime flag indicates if the AddIn is loaded for the first time.
' Initialize AddIn members.
m_inventorApplication = addInSiteObject.Application
' Check for the file
FileVersionCheck()
End Sub
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
