Vault Versions Slowing Drawing Open
jake_egley
jake_egley
Some drawings (.dwg) that I open in Inventor take anywhere from 10-60+ seconds or so when opening. The drawing will open and be visible - and for like a split second my cursor will be able to highlight something on the drawing - and then the loading cursor comes up and spins for ages. I believe what is happening is that after it opens the drawing - it then loads all the vault versions. I confirmed this by unloading the vault add-in and opening the same drawing - it opens instantly.
Is there anyway to fix this? I still need to use vault - but I don't need it to load all the old versions of the drawing on open.
Jake Egley
Inventor 2022
bradeneuropeArthur
what happens if you use another view for example "Where Used" is it than quicker?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
jake_egley
I don't understand what you mean, can you clarify?
Jake Egley
Inventor 2022
bradeneuropeArthur
if you use one of these tabs:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
jake_egley
Hi Arthur, unfortunately the "where used" and "uses" tabs are only visible after the drawing has loaded. The slowness is while the drawing opens.
Jake Egley
Inventor 2022
