Sclae on tile block with Ilogic
srionde
srionde
Hello all,
I am using this code to put scale on block and use before save document as trigger, however if I have more than one page on my idw file, everytime i  save, I always go back to the last page.
Is this anyway to keep same page ?
For Each Osheet In ThisApplication.activedocument.sheets
    ActiveSheet=ThisDrawing.Sheet(osheet.Name)
    If osheet.TitleBlock Is Nothing Or osheet.drawingviews.count=0 Then Exit Sub
 otitleblock=osheet.TitleBlock
 otextboxes=otitleblock.definition.sketch.textboxes
 For Each otextbox In otextboxes
     If otextbox.text= "<ÉCHELLE>" Then
        drawingviewname =ThisApplication.activedocument.ActiveSheet.drawingviews.item(1).Name
        otitleblock.setpromptresulttext(otextbox, ActiveSheet.View(drawingviewname).ScaleString)
    End If
Next
Next
ThisApplication.activedocument.sheets.item(1).activate
InventorVb.DocumentUpdate()
MechMachineMan
I would think your 2nd last line accomplishes this.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
srionde
Unfortunatly no, when it still the same even without this line
Owner2229
      End If
    Next
Next
Hope this will work for you...
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
srionde
Thanks a lot it's working pretty good now !!!
However I had a mistake when using the code, at this line :
drawingviewname =ThisApplication.activedocument.ActiveSheet.drawin?gviews.item(1).Name
So i copy and paste the line from my previous code. which exactly the same as yours and it worked ??!!.
And i see now writing this email the line I copy and paste from you has a ? on it which is not here on my inventor.
I use the same rule to write 'View Scale'
I have a problem when I save the documents.
My rule:
For Each osheet In ThisApplication.activedocument.sheets
    If oSheet.TitleBlock Is Nothing Or osheet.drawingviews.count=0 Then Exit Sub
        If otextbox.text="<View Scale>" Then
            drawingviewname=ThisApplication.activedocument.ActiveSheet.drawingviews.item(1).Name
        End If
    Next
Next
ThisApplication.ActiveDocument.Sheets.Item(ActiveSheet).Activate
I would like to ask some help. I can't understand how work this rule.
Thank the help.
