Styles Editor- Holes Table question
Hi Folks!
Recently we updated to Inventor PRO 2016 from 2015 version.
And Somehow got some problems with my styles for holes table.
Not sure what is going wrong here. My library is open for Read-Write and saved locally. I attached coupld of snapshots, maybe someone could help me to get a clue what is going wrong here.
Style in the library does not match to what is actually happening on the drawing.
Problem is that it is taking style from somewhere else and I can't figure out where from...
Attached a picture of what the style actually looks like...
Ok, I found what went wrong there, but I am a bit confused.
In Styles library I use Note Format- THRU, but somrhow holes table uses another Note Format- BLIND.
How can by default make table hole to use same note format as in the stle library?
For now I just changed BLIND note format in style library, so it actually looks like I need it.1.JPG
problem solved- it was because I installed 2016 version and 2015 was deleted and somehow text font, called AIGDT was removed.
So I had to install this text font on my machine and everything is fine again.
