Retrieving parts informations into Assembly with Ilogic
Message 1 of 9
Greetings everyone,
I've been looking around for this, although I found small pieces of solutions, mixing them did not work as expected haha.
Anyway here's my situation:
I'm currently in a Assembly. I have 3 parts in that said assembly. Thru Ilogic, I need to retrieve the part number and the description of each part into customs properties in the assembly.
Text exemple:
Assy1:
   - Part1
          a) Part number: XXXX
          b) Description : YYYY
   - Part2
          b) Description: YYYY
   - Part 3
Thanks a lot
G. Thibeault
Replies (8)
Message 2 of 9
ADSKDJW4
Hello GThibeault,
I will move this post into the Inventor customization forum as the ILogic questions are better served there to be answered. This is where the customization questions get better visibility.
Best Regards,
Don Warner
Message 3 of 9
MechMachineMan
Check this out:
http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 9
Thanks for the reply. Unfortunately, I've already read that web page and tried the code, and no luck.
the command "SET" isn't supported anymore, and the .DisplayName get me an error saying the argument needs to be in between paranthesis...
Message 5 of 9
MechMachineMan
The Set command isn't supported directly in iLogic because it is vba style.
Getting rid of the set would make it work perfect.
Try .displayname ()
Justin K
Message 6 of 9
Yes I removed the Set.
Here's a screenshot of the actual code
I tried to enclose the oRefDoc.DisplayName into paranthesis. No error from the console but when I run the rule, nothing happens.
Message 7 of 9
MechMachineMan
I think the Debug.Print is for use in the Visual Studio/VBA environment.
If you are just coding in inventor, replace that line with
MsgBox(oRefDoc.DisplayName, MsgBoxStyle.OkOnly, "TITLE OF BOX")
or simply MsgBox(oRefDoc.DisplayName)
in order to pop-up a window to see what is happening realtime
Justin K
Message 8 of 9
Oh god I look stupid... lolll
Well anyway, thank you, it is working so far!! Now I'll try to code the rest in order to achieve my goal!
Message 9 of 9
MechMachineMan
Haha it's all good. Coding/ learning to code is definitely a struggle... especially if it is your first programming language as well.
Feel free to ask away if you get caught on anything else! I'm happy to help as long as a see effort being put it and not just someone expecting hand-outs.
Justin K
