Template Errors
Template Errors
ASchlaack
Template Errors
ASchlaack
So my company has had a template for sheet metal and normal parts for years. And within the past year or two we added in some extrenal rules to it. But this issue we've started to have is that the machines won't always pull up the extrinal rules when a new file is made.
Orignally we had to add the rules to each machine individually, the rules wouldn't just automatically pull up with the template.
Is there a fix for this?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
Owner2229
This should probably fix it:
Create new document (for both part and assembly) > open iLogic rules > add the external rules you want to run (if they arent) > set up trigger events > save template as the original template (replace it)
do this for all your templates and add all external rules to all machines you want to run them on
Hope it helps,
Mike
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
ASchlaack
Thank you, this is what I figured I would have to do and have been doing. I just wanted an second persons say so to make sure there wasn't an easier way.
Aaron Schlaack
