Run a external rule when a user parameter is changed?
S_Verbeek
S_Verbeek
is ther a way to run a external rule when a user parameter is changed?
In the event trigger it is only possible with model parameter but not with user parameters.
Best regards
Stefan
__________________________________________________________________________________
Stefan Verbeek
Mitarbeiter Support bei
bradeneuropeArthur
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
