Call dll from iLogic
Message 1 of 12
Hi All
I am new to the .net but have used iLogic for some time. I have tried to reference a sub inside a Class (dll file).
I have some parameters that I want to set from the dll.
Parameter "Lenght1" and "Width1" exist in the model file
I can call the sub and receive the msgBox but I cannot figure out how to set parameters from the dll through iLogic.
I get the following error message:
"Object reference not set to an instance of an object."
Can anyone help me with setting the parameters? Or point me in the right direction
See simplified example below:
'iLogic call
AddReference "System.Runtime"
AddReference "C:\Vault\Designs\Testing\iLogic_VB\SubCall.dll"
Parameter.UpdateAfterChange = True
MultiValue.UpdateAfterChange = True
iLogicVb.UpdateWhenDone = True
Dim tool as New SubCall.ClassSubCall
tool.Testing(UserAnswer) 'Yes or No
  tool.Parameter = Parameter
  tool.MultiValue = MultiValue
  tool.Length1 = Parameter("Length1")
  tool.Width1 = Parameter("Width1")
'dll file
Imports Autodesk.iLogic.Interfaces
Public Class ClassSubCall
Public Parameter As IParamDynamic
Public MultiValue As IMultiValueParam
Public ILogicVB As ILowLevelSupport
Public Length1 As Double
Public Width1 As Double
Public Sub Testing(ByVal UserAnswer As String)
If UserAnswer = "Yes" Then
MsgBox("OK, message received")
Parameter("Length1") = 100
Parameter("Width1") = 50
Else
MsgBox("No message received")
Parameter("Length1") = 150
Parameter("Width1") = Parameter("Length1") / 2
End Sub
End Class
Replies (11)
Message 2 of 12
bradeneuropeArthur
you need to create a New statement:
Public Sub new(ByVal UserAnswer As String)
Else
End Sub
End Class
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
Hi
I am not quite following you. Is this necessary only on Subs? Works fine on functions. Perhaps it is possible to return an array
Call from iLogic (model opdates fine)
AddReference "C:\Vault\Designs\KH test\Testing\iLogic_VB\SubCall.dll"
Length1=tool.FunctionTest(UserAnswer)
dll content
Public Function FunctionTest(ByVal UserAnswer As String)
FunctionTest = 100
Else
FunctionTest = 150
End Function
End Class
Message 4 of 12
bradeneuropeArthur
Try to test with only a message box. You will see that nothing happens on the new statement
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 12
Thanks for your tips... But I think that I am missing the basics
Can you refer to any articles etc. for best practice on this area?
Message 6 of 12
bradeneuropeArthur
Tell me what your code needs to do.
I will send you an example asap
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 12
Any help would be appreciated.
This is on a Proof Of Concept level.
Based on a specific answer from the user in Form1 I want to retreive the Dimensions Width1 and Length1 from a dll and update the model. Hopefully this is clear.
The Form1 is an iLogic form not from the .NET
Message 8 of 12
bradeneuropeArthur
Sorry.
But I think your code is correct.
it works with this:
 Dim Tool As ClassSubCall.ClassSubCall = New ClassSubCall.ClassSubCall()
        'a.FunctionTest("aa")
        MsgBox(Tool.FunctionTest("Yes"))
        'Length1 = Tool.FunctionTest("Yes")
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 12
Hi
Yes it works with the function test. But here I can only retreive one value.
FunctionTest = 100
Else
FunctionTest = 150
End Function
If I try to do the same with a Sub and set multiple values and try to set the Length1 and Width1
Else
Parameter("Width1") = 75
End Sub
It does not produce a value...
MsgBox(tool.Testing("Yes"))
Message 10 of 12
bradeneuropeArthur
Hoi should define an array. And return that
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 12
smilinger
Apparently you made a mistake by using the Parameter member in your Testing method before it's assigned a value. You should write this line:
before this line:
Or you should do that in a Constructor, aka Sub New() as suggested by @bradeneuropeArthur in the 2nd post.
Message 12 of 12
Could it really be that simple? Yes it could...
Thanks for the support, both of you. Very much appreciated
