iLogic Error Message
Lesoux
Lesoux
Hi everybody.
Just got pretty interesting error message on iLogic rule creation/editing (see picture below). Never seen that before.
Yesterday just installed AutoCAD Mechanical 2018. Inventor 2018 & ETO 2018 already were installed long time ago.
Any ideas?
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Inventor 2020.3.4, Build 373
Mark.Lancaster
@Lesoux
Actipro is a provider of .net interface.  Either you have a 3rd party program (not related to Inventor) installed on your machine related to this or you have a netframe corruption on your machine.  Time to get IT involved..  Smiley Wink
Update:  Also check your Windows Event log around this message appeared.
Mark Lancaster
Lesoux
Removing AutoCAD and reinstalling .NET 4.7 resolved the issue with Inventor iLogic. Thanks for the help.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
jan.kubeczka
I have used public subroutine for swap appearance library from Autodesk to RAL (subroutine has published on the forum) and I have modified it:
SyntaxEditor Code Snippet
Public Sub SetOccurrenceAppearance()
    Dim asmDoc As AssemblyDocument
    asmDoc = ThisApplication.ActiveDocument
    ' Get an appearance from the document.  To assign an appearance is must
    ' exist in the document.  This looks for a local appearance and if that
    ' fails it copies the appearance from a library to the document.
    Dim localAsset As Asset
    On Error Resume Next
    localAsset = asmDoc.Assets.Item("RAL")
	MessageBox.Show(Err, "Title")
    If Err Then
        On Error GoTo 0
        ' Failed to get the appearance in the document, so import it.
        ' Get an asset library by name.  Either the displayed name (which
        ' can changed based on the current language) or the internal name
        ' (which is always the same) can be used.
        Dim assetLib As AssetLibrary
        assetLib = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9")
        ' assetLib = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
        ' Get an asset in the library.  Again, either the displayed name or the internal
        ' name can be used.
        Dim libAsset As Asset
        libAsset = assetLib.AppearanceAssets.Item("0AD2A068-7D2B-40D5-BF3C-54412B7563E2")
        ' libAsset = assetLib.AppearanceAssets.Item("RAL")
        ' Copy the asset locally.
        localAsset = libAsset.CopyTo(asmDoc)
    On Error GoTo 0
    ' Have an occurrence selected.
    Dim occ As ComponentOccurrence
    occ = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select an occurrence.")
    ' Assign the asset to the occurrence.
    occ.Appearance = localAsset
End Sub
But there is error message:
Error on line 21: Value of he type Microsoft.VisualBasic.ErrObject can't convert to Boolean.
(That is my translate from Czech - excuse me).
PLease, help me. Thank you very much.
Jan
