Proper way to resolve obsolete 'AsAny' in Inventor 2025 VB AddIn Template (PictureDispConverter)
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I'm using Visual Studio 2022 (Version 17.12.2)
I'd like to know the correct way to resolve the "'AsAny' is obsolete" (BC40000) when create new project using Autodesk Inventor 2025 VB AddIn Template (PictureDispConverter class) supplied with SDK
How do I set Small and Large icons of AddIn button?
@JelteDeJong isn't it time to update your article "Adding icons to your buttons"?
PS:
BTW, why C# AddIn Template doesn't contain PictureDispConverter class?
Please vote for Inventor-Idea Text Search within Option Names
bradeneuropeArthur
Isn't this just a warning and not an error?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Maxim-CADman77
Yes VS classifies this issue as warning ('just' underlines the call with green curled and partially strikethrough it - definitely not something worth an attention 🙂 ).
UPDATE:
MS Copilot suggested to replace 'AsAny' to 'Struct' but then it stopped working.
Michael.Navara
This question is good point. I try to look at this and my solution is to overload OleCreatePictureIndirect method for Icon and Bitmap.
You can see the PictureDispConverter code on my GitHub.
Maxim-CADman77
For those interested here is the VB net version of Michael's code:
    Public NotInheritable Class PictureDispConverter
        Shared ReadOnly iPictureDispGuid As System.Guid = GetType(stdole.IPictureDisp).GUID
        'Shared ReadOnly HandleCollector As New HandleCollector("Icon handles", 1000)
        ' Converts IPictureDisp to Icon if it is possible
        Public Shared Function PictureDispToIcon(pictureDisp As stdole.IPictureDisp) As Icon
            Dim icon As Icon = Nothing
            If pictureDisp IsNot Nothing AndAlso pictureDisp.Type = CType(3, Short) Then
                icon = Icon.FromHandle(New IntPtr(pictureDisp.Handle))
            End If
            Return icon
        End Function
        ' Converts IPictureDisp to Image if it is possible
        Public Shared Function PictureDispToImage(pictureDisp As stdole.IPictureDisp) As Image
            Dim image As Image = Nothing
            If pictureDisp IsNot Nothing Then
                If pictureDisp.Type = CType(1, Short) Then
                    Dim hpalette As IntPtr = New IntPtr(pictureDisp.hPal)
                    image = Image.FromHbitmap(New IntPtr(pictureDisp.Handle), hpalette)
                End If
                If pictureDisp.Type = CType(2, Short) Then
                    image = New Metafile(New IntPtr(pictureDisp.Handle), New WmfPlaceableFileHeader())
                End If
            End If
            Return image
        End Function
        ' Converts an Icon into a IPictureDisp
        Public Shared Function ToIPictureDisp(icon As Icon) As stdole.IPictureDisp
            Return OleCreatePictureIndirect(New PictDesc.Icon(icon), iPictureDispGuid, True)
        End Function
        ' Converts an Image into a IPictureDisp
        Public Shared Function ToIPictureDisp(image As Image) As stdole.IPictureDisp
                If(TypeOf image Is Bitmap, New PictDesc.Bitmap(DirectCast(image, Bitmap)), New PictDesc.Bitmap(New Bitmap(image))),
        End Function
        <DllImport("OleAut32.dll", PreserveSig:=False)>
        Private Shared Function OleCreatePictureIndirect(pictDescIcon As PictDesc.Icon, ByRef iid As System.Guid, fOwn As Boolean) As stdole.IPictureDisp
        End Function
        Private Shared Function OleCreatePictureIndirect(pictDescBitmap As PictDesc.Bitmap, ByRef iid As System.Guid, fOwn As Boolean) As stdole.IPictureDisp
        End Function
        Private NotInheritable Class PictDesc
            Public Const PicTypeUninitialized As Short = -1
            Public Const PicTypeNone As Short = 0
            Public Const PicTypeBitmap As Short = 1
            Public Const PicTypeMetafile As Short = 2
            Public Const PicTypeIcon As Short = 3
            Public Const PicTypeEnhMetafile As Short = 4
            <StructLayout(LayoutKind.Sequential)>
            Public Class Icon
                Friend cbSizeOfStruct As Integer = Marshal.SizeOf(GetType(PictDesc.Icon))
                Friend picType As Integer = PicTypeIcon
                Friend hicon As IntPtr = IntPtr.Zero
                Friend unused1 As Integer
                Friend unused2 As Integer
                Friend Sub New(icon As System.Drawing.Icon)
                    Me.hicon = icon.ToBitmap().GetHicon()
                End Sub
            End Class
            Public Class Bitmap
                Friend cbSizeOfStruct As Integer = Marshal.SizeOf(GetType(PictDesc.Bitmap))
                Friend picType As Integer = PicTypeBitmap
                Friend hbitmap As IntPtr = IntPtr.Zero
                Friend hpal As IntPtr = IntPtr.Zero
                Friend unused As Integer
                Friend Sub New(bitmap As System.Drawing.Bitmap)
                    Me.hbitmap = bitmap.GetHbitmap()
                End Sub
            End Class
        End Class
    End Class
And I believe there are two more minor edits to the original code needed (use 'System.Guid' instead of 'GUID' in both Picture and Bitmap variants of the OleCreatePictureIndirect Function):
End Function
End Function
Dear @johnsonshiue
Could you, please, ask the Inventor team to make appropriate updates in VB Template included to SDK of further Inventor releases?
