Autodesk Inventor Vb.Net "AddIn" - Set Part Colour Using RGB Values
isocam
isocam
Can anybody help?
I am writing a Autodesk Inventor Vb.Net "AddIn" to set the part colour using RGB Values.
Here is my code so far....
Imports Inventor
Module Module01
Sub SetPartColour(oDoc As Document)
Dim invApp As Inventor.Application = ThisApplication
Dim oAppearance As Asset = oDoc.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "CustomAppearance")
Dim oColor As ColorAssetValue = oAppearance.Item("generic_diffuse")
Dim red As Byte = 255
Dim green As Byte = 0
Dim blue As Byte = 0
Dim oColorObj As Color = invApp.TransientObjects.CreateColor(red, green, blue)
oColor.Value = oColorObj
Dim oExtrudeFeature As ExtrudeFeature = oDoc.ComponentDefinition.Features.ExtrudeFeatures.Item(1)
oExtrudeFeature.Appearance = oAppearance
End Sub
End Module
I am having issues in the above code, highlighted in red.
Does anybody know what is wrong, and can you update the code?
Many thanks in advance!
Darren
C_Haines_ENG
Are you trying to set the material as well? And to clarify you are using VBA or are you using iLogic?
isocam
I am trying to write an addin using Vb.Net
All I need is to set the colour, not the material.
Kindest Regards
Darren
C_Haines_ENG
Its in iLogic but you should be able to work it to VBA.
Sub Main
	Dim oDoc As PartDocument = ThisDoc.Document
	Dim R As Integer = 255
	Dim G As Integer = 0
	Dim B As Integer = 0
	Dim NewColor As Asset
	Try
		NewColor = oDoc.Assets.Item("Custom Color")
	Catch
		NewColor = oDoc.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", _
		"Custom Color", "Custom Color")
	End Try
	Dim oColor As ColorAssetValue = NewColor.Item("generic_diffuse")
	oColor.Value = ThisApplication.TransientObjects.CreateColor(R, G, B)
	oExtrudeFeature.Appearance = NewColor
End Sub
