- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I am using Vba or Vb.net to "launch_Viewer" of the pdf file after creation, it is not previewed.
I have seen that the option in the API is set but it is not checked in the option dialogbox.
Something has changed regarding this since inventor 2012.
With inventor 2012 it was working correctly.
But with inventor 2018 it is not working anymore.
After the code it is still not checked an the pdf is not previewed.
Module MdlExport Public Sub ExportPdf(oInvApp As Inventor.Application, strExportRoot As String, strSuffix As String) ' Get the PDF translator Add-In. Dim PDFAddIn As TranslatorAddIn PDFAddIn = oInvApp.ApplicationAddIns.ItemById("{0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = oInvApp.ActiveDocument Dim fi As System.IO.FileInfo fi = New System.IO.FileInfo(oDocument.FullFileName) Dim strDirPath As String strDirPath = fi.DirectoryName Dim strDirName As String strDirName = fi.Directory.Name Dim strFileNameNoExtension As String strFileNameNoExtension = System.IO.Path.GetFileNameWithoutExtension(oDocument.FullFileName) 'MsgBox(strFileNameNoExtension) Dim strFileRootPath As String strFileRootPath = System.IO.Path.GetPathRoot(oDocument.FullFileName) Dim strNewDirFilepath As String strNewDirFilepath = Replace(strDirPath, strFileRootPath, strExportRoot & ":\") 'MsgBox(strFileNameNoExtension) Dim oContext As TranslationContext oContext = oInvApp.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = oInvApp.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = oInvApp.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then oOptions.Value("Launch_Viewer") = true end if Try MkDir(strNewDirFilepath) Catch ex As Exception End Try 'Set the destination file name oDataMedium.FileName = strNewDirFilepath & "\" & strFileNameNoExtension & strSuffix & ".Pdf" 'Publish document. Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) end sub end module
After the code it is still not checked an the pdf is not checked an not previewed.
Any idea how to preview the pdf.
Remarks:
The same issue is seen with the DwfAddin.
This could be a bug.
Please Autodesk take this in review If this is a bug.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
