PartsLists.Add
PartsLists.Add
DFogliazza
583件の閲覧回数
5件の返信
メッセージ1/6
PartsLists.Add
DFogliazza
I have trouble finding the right code for PartsLists.Add in iLogic
Using Inventor 2017
When you insert a partlist normally you can select the "part list view" and there are 4 options: Structured, Part only, Structured (existing), Part only (existing).
I need to select trough ilogic the third option (structured existing): how do I do it?
oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint, ????)
Thanks everybody!
0 件のいいね
584件の閲覧回数
5件の返信
返信 (5)
メッセージ2/6
bradeneuropeArthur
Try
oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint, PartsListLevelEnum.kStructured)
Catch ex As Exception
Try
oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint, PartsListLevelEnum.kStructuredAllLevels)
Catch ex2 As Exception
MsgBox("Check Assembly BOM: Is not Structured or Stuctured All Levels")
End Try
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
0 件のいいね
メッセージ3/6
DFogliazza
Nope, not working. Still "Structured" parlist: I need the "Structured (existing)"
BTW missing and End Try on the code
0 件のいいね
メッセージ4/6
bradeneuropeArthur
you need to activate this in the assembly first!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
メッセージ5/6
DFogliazza
Sorry, my bad on the translation. (see pic attached)
Structured (legacy)
0 件のいいね
メッセージ6/6
bradeneuropeArthur
Can't find this within the API too!
Maybe this is not supported.
Let's ask @Anonymous if this is the Case
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 件のいいね
