problem to locate inventor addin
TechInventor20
Message 1 of 19
TechInventor20
Goodmorning,
I'm currently very busy to locate a inventor addin. A collegue of mine has copied all the addins of his previous boss. But know we want to get it working on our server. The problem is that we don't get it to work. I will attatch the files below. could someone help us with this?
Maybe need to mention that we don't have Visual studio
Thomas de Vries
Replies (18)
Message 2 of 19
bradeneuropeArthur
i will guide you keep reading...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 19
bradeneuropeArthur
Copy add-in dll file to one of following locations:
a) Anywhere, then *.addin file <Assembly> setting should be updated to the full path including the dll name
b) Inventor <InstallPath>\bin\ folder, then *.addin file <Assembly> setting should be the dll name only: <AddInName>.dll
c) Inventor <InstallPath>\bin\XX folder, then *.addin file <Assembly> setting shoule be a relative path: XX\<AddInName>.dll
3) Copy.addin manifest file to one of following locations:
a) Inventor Version Dependent
Windows XP:
C:\Documents and Settings\All Users\Application Data\Autodesk\Inventor 2012\Addins\
Windows7/Vista:
C:\ProgramData\Autodesk\Inventor 2012\Addins\
b) Inventor Version Independent
Windows XP:
C:\Documents and Settings\All Users\Application Data\Autodesk\Inventor Addins\
Windows7/Vista:
C:\ProgramData\Autodesk\Inventor Addins\
c) Per User Override
Windows XP:
C:\Documents and Settings\<user>\Application Data\Autodesk\Inventor 2012\Addins\
Windows7/Vista:
C:\Users\<user>\AppData\Roaming\Autodesk\Inventor 2012\Addins\
4) Startup Inventor, the AddIn should be loaded
To unregister the AddIn, remove the Autodesk.<AddInName>.Inventor.addin from above mentioned .addin manifest file locations directly.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 19
TechInventor20
Hi, Thank you for te quick response.
That part we allready knew but we don't quite get what we need to do. What file we need to use or map we need to place.
In some of the .dll files and other files are diffrent locations mentiond. (like old locations from the previous boss)
hope you understand me more, if not just ask.
mvg Thomas de Vries
Message 5 of 19
bradeneuropeArthur
let's take a look
do you have the *.dll file
do you have the *.addin file
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 19
TechInventor20
If you can look in my zipfile you can find both of them. but within the code are some Filelocations mentiont, but we can't chance them because we can't rewrite them somehow.
Message 7 of 19
TechInventor20
look, these are the files and where they are located.
Message 8 of 19
bradeneuropeArthur
I will take a look
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 19
bradeneuropeArthur
iPolem/Autodesk.iPolem.Inventor.addin Copy to C:\ProgramData\Autodesk\Inventor 20##\Addins
iPolem/obj/Debug/iPolem.dll Copy To C:\Program Files\Autodesk\Inventor 20##\Bin
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 19
TechInventor20
i'm sorry but it won't work. when I close inventor en start it up again there is no Add-in....
I think i give it up....
Message 11 of 19
bradeneuropeArthur
also not in the addin menu from inventor?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 19
bradeneuropeArthur
open your add in file with notepad
paste this in;
<Addin Type="Standard">
<!--Created for Autodesk Inventor Version 16.0-->
<ClassId>{5bee0fd2-d309-49ba-be17-f7681281eb0a}</ClassId>
<ClientId>{5bee0fd2-d309-49ba-be17-f7681281eb0a}</ClientId>
<DisplayName>iPolem</DisplayName>
<Description>iPolem/Description>
<Assembly>iPolem.dll</Assembly>
<LoadOnStartUp>1</LoadOnStartUp>
<UserUnloadable>1</UserUnloadable>
<Hidden>0</Hidden>
<SupportedSoftwareVersionGreaterThan>15..</SupportedSoftwareVersionGreaterThan>
<DataVersion>1</DataVersion>
<UserInterfaceVersion>1</UserInterfaceVersion>
</Addin>
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 19
TechInventor20
hi,
Well, unforunally it doesn't work....
But did you take a look inside some of the important codes? because some of the codes are refering to old locations. (I think)
And do I have to copy the Whole map to some kind of place?
little question, how does inventor know where to look for addins? especially the .dll files, because in de map iPolem are like 25 of them.
Thomas de Vries
Message 14 of 19
bradeneuropeArthur
that is exactly what i have changed in the addin file.
the location should be ok with these settings
<Hidden>0</Hidden>
</Addin>
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 19
bradeneuropeArthur
The addin file was configured wrong:
<Description>iPolem</Description>
<Hidden>0</Hidden>
</Addin>
put this in and it will load.
BUT this is not a Add-in I think!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 19
TechInventor20
Thanks I will check if it works.
Why do you think it is not an addin?
Message 17 of 19
bradeneuropeArthur
Because it is not configured like that in the programming.
Because i only see executable and no programming within the add in!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 19
TechInventor20
I think that we put this project beside us. I don't think that we can solve the problem... Many thanks Arthur!
May i help you sometimes in the future!!
Message 19 of 19
bradeneuropeArthur
I have it loaded!
But i don't see any buttons etc!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
