Share or export global event triggers
isidro.nunez
isidro.nunez
Hello all, this is my first post in this forum. I have found a lot of help in this forum before, thank you in advance!
Now, I have a problem but I can't find how to solve it. I need to share or export my global event triggers to other computers. There is any way I can copy this settings? I have been looking into the config files in my local folder, but no luck.
Thank you
JhoelForshav
Hi @isidro.nunez
I think this is the information you're looking for 🙂
Sharing Triggers
The external triggers for All documents, Parts, Assemblies, and Drawings are stored in RulesOnEvents.xml. This file is located in the first External Rules Directory as specified in the iLogic Configuration dialog box.
Note: Triggers for the This Document tab are stored directly in the current document.
RulesOnEvents.xml is a single file that can be shared and stored on a network drive. The file can only be modified by one user at a time. Set the file to read-only or change its permissions to prevent others from modifying the data.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Inve...
isidro.nunez
Thank you so much @JhoelForshav , it's working fine!
