Adding sketch to drawing view
NachoShaw
Advisor Advisor
NachoShaw
Hey
i need to add a sketch to a drawing view. The sketch is a rectangle that is 1cm larger all round to the drawing view. I was looking at oView.Position and then deducting the width but it wasnt working for me.
any help very much appreciated
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
bradeneuropeArthur
Something like this:
Public Sub DWGVIEW()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim c As Sheet
Set c = b.ActiveSheet
Dim d As DrawingView
Set d = c.DrawingViews.Item(1)
MsgBox (d.Width)
 Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
Dim x As Point2d
Dim y As Point2d
Dim z As Point2d
Set x = oTransGeom.CreatePoint2d(-(d.Width * 20) / 2, -(d.Height * 20) / 2)
Set y = oTransGeom.CreatePoint2d(d.Width * 20, -(d.Height * 20) / 2)
Set z = oTransGeom.CreatePoint2d(d.Width * 20, d.Height * 20)
'd.Sketches.Add.SketchLines.AddAsThreePointRectangle d.Width, d.Width, d.Height
'd.Sketches.Add '.SketchLines.AddByTwoPoints( x, y )(oTransGeom.CreatePoint2d(0, 0), oTransGeom.CreatePoint2d(10, 0))
Dim s As DrawingSketch
Set s = d.Sketches.Item(1)
 s.Edit
'Call s.SketchLines.AddByTwoPoints(x, y)
Call s.SketchLines.AddAsThreePointRectangle(x, y, z)
s.ExitEdit
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Dim c As Sheet
Dim CenterView As Point2d
Dim x As Point2d
Dim y As Point2d
Dim z As Point2d
Set x = oTransGeom.CreatePoint2d(-(d.Width * 10) - 14 / 2, -(d.Height * 10) - 14 / 2)
Set y = oTransGeom.CreatePoint2d(d.Width * 10 + 14, -(d.Height * 10) + 14 / 2)
Set z = oTransGeom.CreatePoint2d(d.Width * 10 + 14, d.Height * 10 + 14)
Set CenterView = oTransGeom.CreatePoint2d(0, 0)
d.Sketches.Add '.SketchLines.AddAsThreePointRectangle d.Width, d.Width, d.Height
 s.Edit
Call s.SketchLines.AddAsTwoPointRectangle(x, z)
s.ExitEdit
End Sub
Dim c As Sheet
Dim x As Point2d
Dim y As Point2d
Dim z As Point2d
 s.Edit
s.ExitEdit
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Final one:
Dim c As Sheet
Dim x As Point2d
Dim y As Point2d
Dim z As Point2d
Set x = oTransGeom.CreatePoint2d(-(d.Width / 2) * 1 / d.Scale - 13, -(d.Height / 2) * 1 / d.Scale - 13)
Set z = oTransGeom.CreatePoint2d(d.Width * 10 + 13, d.Height * 10 + 13)
d.Sketches.Add
s.Edit
s.ExitEdit
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
NachoShaw
Hey
i was able to get what i needed working.
much appreciated mate
Nacho
