Inventor symbol server (debug)
Rene_Gerlach
Message 1 of 16
Rene_Gerlach
Is there any symbol server for Inventor, like AutoCAD ( http://symbols.autodesk.com/symbols)?
Replies (15)
Message 2 of 16
bradeneuropeArthur
Insert the symbols into an inventor drawing.
You can either use it as template or you make a reference as symbol library in inventor.
Depends on what version of inventor you use....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 16
Rene_Gerlach
Hi @bradeneuropeArthur,
thanks for your answer, but I'm searching not for symbols for drawings.
I try to debug a crash and want to see the full call stack, to check if our addin is responsible for the crash.
So I need the debug symbols (pdb files) for Inventor.
Cheers
Rene
Message 4 of 16
bradeneuropeArthur
Hi.
Sorry I don't exactly understand what you try to do.
What symbols do you mean?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 16
Rene_Gerlach
if you develop c++ or .net addins each generate for debugging purposes also a .pdb file, this will be called "symbol" file.
With this file you can debug the addin after compiling to a dll. These symbol files can have a full debug information or only function names.
I'm searching for the function names pdb for Inventor now. I try to find out why Inventor crashes and for this I want to analyze the call stack.
Cheers
Rene
Message 6 of 16
bradeneuropeArthur
Can't you find them in the bin- folder?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 16
Rene_Gerlach
Unfortunately not.
For AutoCAD exists a symbol server. I hoped that this will also exists for Inventor.
Message 8 of 16
bradeneuropeArthur
You can find the dll files there!
Maybe s full search with the file name for your system!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 16
Rene_Gerlach
I'm not searching for the dll's. I'm searching for the corresponding pdb's.
And these are not in the installation, or do you have the pdb's in your bin folder?
Sample:
Inventor.exe -> Inventor.pdb
WpfHost.dll -> WpfHost.pdb
and so on...
Cheers
Rene
Message 10 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
Hello @Rene_Gerlach,
Unfortunately, Inventor will not provide any .pdb file at present.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 11 of 16
Rene_Gerlach
Hi @chandra.shekar.g
bad news.
Any plans to do so?
It would be easier to find some issues.
Cheers
Rene
Message 12 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
Currently, crash report will be sent to engineering team and debugged to trace error.
You can suggest wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 16
Rene_Gerlach
Hallo @chandra.shekar.g,
we have send so many crash reports, but nothing happen.
So we want analyze the issue self.
May be you can make an connection between us and the developers.
I will generate a wish on idea station.
Cheers
Rene
Message 14 of 16
Rene_Gerlach
Create an idea on idea station: #7887023
Cheers
Rene
Message 15 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Rene_Gerlach,
To analyze crash, can you please reply to mail with crash report?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 16 of 16
Rene_Gerlach
Hi @chandra.shekar.g,
send the crash reports to case Id.
Cheers
Rene
