View Orientation Normal to active sketch
j_weber
Mentor Mentor
j_weber
Hi everybody
with help I create the following code to create a sketch on the xy-plane
'Set a reference to the part dokument
Dim oDoc As Inventor.Document
oDoc = ThisDoc.Document
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
oCompDef = oDoc.ComponentDefinition
' Create a new sketch on the X-y work plane.
Dim oSketch As PlanarSketch
oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
oSketch.Edit
'project origin point
Dim oOriginSketchPoint As SketchPoint
oOriginSketchPoint = oSketch.AddByProjectingEntity(oCompDef.WorkPoints.Item(1))
It work perfect and reduce the clicks a little bit.
The last thing to make it very perfect is to change the view normal to the sketchplane. Like it is in the sketch command
I think i must change the camara eye but I'm a beginner in programming so I hope someone of the cracks can help me.
Thanks and greetz
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
rogmitch
Hi Jorg,
How about...
 oDoc.SelectSet.Select oSketch
Dim oControlDef As ControlDefinition
Set oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppLookAtCmd") 'Look at the sketch
oControlDef.Execute
Doevents 'May not need this
Good luck
Roger Mitchell
j_weber
Hi Roger,
thanks for help.
I think that is the way I must look for.
Thanks again an a nice weekend.
Jörg Weber
