Find Dimension Overrides using iLogic
Veerappa
Veerappa
Hi All,
I got this ilogic rule in forum. Is it possible to change override dimension text height? Because it is very difficult to read in large drawings.
'-------------Start of ilogic ------------------------------------------------
' Set a reference to the active document.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
'Define the drawing dims collection
Dim oDrawingDims As DrawingDimension
'Dim oColor As Inventor.Color
Dim oColor As Color
'Prompt user to choose highlight / un-highlight
Dim booleanParam as Object
booleanParam = InputRadioBox("Select an Option", _
"Hightlight Overrides", "Un-Hightlight Overrides", True, Title := "iLogic")
'Loop through all dimensions and set colors
For Each oDrawingDims In oDoc.ActiveSheet.DrawingDimensions
   If booleanParam = True then
   'set color to magenta
   oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 255)
   else
   'set color to black
   oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
   oColor.ColorSourceType = ColorSourceTypeEnum.kLayerColorSource
   end if
   if oDrawingDims.HideValue = True _
   or oDrawingDims.ModelValueOverridden = True then
   oDrawingDims.Text.Color = oColor
   Else
   End if
Next
'-------------End of ilogic ------------------------------------------------
KT. Veerappa
MechMachineMan
Something like the below code might work...
But why not just create a different text style with a larger/smaller text size, use the shift+right click menu to select all dims, then swap the style back and forth as necessary?
newsize = InputBox("Enter new text height in cms", "Ha", ".125")
       oDrawingDims.Text.FormattedText = "<StyleOverride FontSize='" & Newsize & "'><DimensionValue/></StyleOverride>"
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
