Python and Inventor
Python and Inventor
ivan.liu
Python and Inventor
ivan.liu
Hi, I would like to get started with using Python to control certain features within Inventor similiar to what can be done with iLogic/VBA. What is the best way to get started with this? I have combed through google and the autodesk inventor forums and haven't really found much documentation on Python and the Inventor API.
Thanks for any help.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hello @ivan.liu,
Hoping that below forum discussion would be helpful to start Python programming with Inventor.
https://forums.autodesk.com/t5/inventor-customization/how-to-get-parameters-and-mass-of-a-part-with-...
Before python coding, com enabling installer for windows (pywin32-221.win-amd64-py3.6.exe) can be downloaded from below link.
https://sourceforge.net/projects/pywin32/files/pywin32/Build%20221/
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
aswin.ramasubramanian
I am trying to use python to access and work Inventor. I am unable to open due to the following error.
com_error: (-2147352567, 'Exception occurred.', (0, None, None, None, 0, -2147024809), None)
I have installed the pywin32 and other modules.
I am using Spyder IDE for coding
Can you kindly help me fix this error please?
