iLogic to Rotate a Revision Table
Hi all,
I've recently created a new drawing sheet format, that includes a vertical (90deg rotated) revision table. Each time I double click on the sheet in the Sheet formats folder, to create a new sheet the new sheet's revision block / table returns to the normal orientation as opposed to being vertical.
I think in order to rectify this I'll need a ilogic rule of sorts to rotate the table.
Thanks in advance for the help!
PS: I have a small code that moves the table according to the page size, so I was thinking the angle can be specified with that?
If ActiveSheet.Size ="A2" Then
PointX = (ActiveSheet.Width/10) - 8 - 1
PointY = 18.6 + 1
End If
If ActiveSheet.Size ="A1" Then
PointX = (ActiveSheet.Width/10) - 8 - 2
PointY = 18.6 + 2
End If
If ActiveSheet.Size ="A0" Then
PointY = 18.6 + 2
End If
Dim oPoint As Point2d
oPoint=ThisApplication.TransientGeometry.Createpoint2d(PointX,PointY)
ActiveSheet.Sheet.RevisionTables.Item("REVISION TABLE").Position=oPoint
InventorVb.DocumentUpdate()
MechMachineMan
oDEG = Degrees of rotation in degrees.
ThisApplication.ActiveDocument.ActiveSheet.RevisionTables.Item("REVISION TABLE").Rotation= oDEG * Math.Pi/180
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for the reply!
I ran the code and it worked once, however I can't seem to change the angle of roation.
Coudl you explain the " * Math.Pi/180" part of the code and how I can manipulate it to achieve various angles?
Thanks again!
Also, is there a way to recall the table's orientation? what I'm thinking to do is write an if statement that says If the table is not equal to 90deg then rotate it
MechMachineMan
Angle in degrees * Pi/180 = angle in radians.. It's just the conversion factor as the .Rotation Method only accepts angle in radians.
Justin K
Thanks a mil! is there a way to trigger this when a new sheet is created?
