multiple drawing sheets delete by select set
marcin_otręba
Advisor Advisor
Message 1 of 11
marcin_otręba
hi,
i'm trying to develope addin to delete bunch of sheets which are selected thru oselect set ( right now i have solution for deleting sheets one by one but it works to long)
it looks something like:
activesheet= drw1.sheets.item(i)
For j = 1 To drw1.Sheets.Count
If j <> i Then
oselset.Select drw1.Sheets.Item(j)
Next
oselset.Delete
but it does not work... any ideas why?
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Replies (10)
Message 2 of 11
MechMachineMan
Because you dont have to use oSelect to delete the sheet; the method is available directly on the object.
If j <> i Then
     drw1.Sheets.Item(j).Delete
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 11
marcin_otręba
i said that i have that solution already but it works too long i need something faster...
Message 4 of 11
MechMachineMan
Do you want to manually select the sheets to be deleted via browser nodes, or do you have some criteria the program could use?
Justin K
Message 5 of 11
marcin_otręba
Yes i hale IT all solved i need ony deleting all in one operation...
Message 6 of 11
MechMachineMan
Dim oSS As SelectSet oSS = ThisApplication.ActiveDocument.SelectSet Try For each oItem As Sheet in oSS oItem.Delete Next Catch Msgbox("Wrong item type found: " & oItem.Type) End try
Justin K
Message 7 of 11
marcin_otręba
I told you already That i have it workin this way what i need is solution when i add to selectset couple of sheets and then i delete them thru oselectset.delete function i can select it clicking on them and then right clicking i can delete it so i belive there is way to do it thru macro, in help i read That. Delete function called From oselectset works for all entites That can be deleted....maybe when in codę i wrote call before deleting it help, right now i dont have Access to my laptop so i will try tomorow, Thanks.
Ps sorry for my english...
Message 8 of 11
MechMachineMan
Why do you need to delete the sheets/ what is your criteria for deleting the sheets?
Justin K
Message 9 of 11
marcin_otręba
I write it to my frientd.., in his company they create drawings for each assembly in one drawing doc placing each part on one sheet i wrote him macro which saves each sheet as drawing but i need to delete rest of sheet From it....
Message 10 of 11
MechMachineMan
Ahhh. Do you have this macro working on documents that are opened invisibly?
Justin K
Message 11 of 11
marcin_otręba
Yup.
