How to address a specific Sketched Symbol in iLogic by name
Hi all,
I have a small code written to move a sketched symbol in my title block when the page size changes. The symbol is a set of prompted text, which is used for sheet specific notes on the drawing. The one issue that I'm having is that I can't figure out how to address the symbol by name, only by it's number, which as you can imagine is problematic.
Any help on this will be appreciated!
If ActiveSheet.Size ="A2" Then
PointX = (ActiveSheet.Width/10) - 1 - 0.5 - (7.5/2)
PointY = 33.4 + 1
If ActiveSheet.Size ="A1" Then
PointX = (ActiveSheet.Width/10) - 2 - 0.5 - (7.5/2)
PointY = 33.4 + 2
If ActiveSheet.Size ="A0" Then
PointY = 33.4 + 2
Dim oPoint As Point2d
oPoint=ThisApplication.TransientGeometry.Createpoint2d(PointX,PointY)
ActiveSheet.Sheet.SketchedSymbols.Item(1).Position=oPoint
InventorVb.DocumentUpdate()
Curtis_Waguespack
Hi Hassonm,
Here's a quick example.
I hope this helps.
Curtis
'Iterate through each symbol in the active sheet
For Each oSymbol In ThisDrawing.Document.ActiveSheet.SketchedSymbols
	'look for the symbol by name
	If oSymbol.Name = "MECHANICAL NOTES" Then
		MessageBox.Show("Sketched Symbol Found", "iLogic")
Next 'next symbol
Curtis_Waguespack
Here's a related rule I use to gather the insert point of a specific sketched symbol, that might or might not be helpful.
Dim MyArrayList As New ArrayList
'Define the drawing document
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisDrawing.Document
'Define the symbol to look for
Dim sSymbol As String
For Each oSymbol In oDrawDoc.ActiveSheet.SketchedSymbols
	'check for duplicates
	If Not (MyArrayList.Contains(oSymbol.Name)) Then
	MyArrayList.add(oSymbol.Name)
	Else
Next
If MyArrayList.Count < 1 Then
MessageBox.Show("No sketched symbols found on this sheet", "iLogic")
Return
Else
'get user input
sSymbol = InputListBox("Select one:", MyArrayList, MyArrayList(0), "iLogic", "List")
i = 0
	If oSymbol.Name = sSymbol Then
	i = i+1 'count symbol
	'get the symbol insert point
	Dim oSymbPoint As Point2d
    oSymbPoint = oSymbol.Position
	'provide user the symbol co-ordinates in an
	'input box, so it can be copied
	'MsgBox(oSymbPoint.x & " " & oSymbPoint.y)
	InputBox("Symbol Insert Co-ordinates" & vbLf & _
	"Symbol Name: " & oSymbol.Name & "(" & i & ") :", _
	"iLogic", oSymbPoint.x & " , " & oSymbPoint.y)
	Else
Next
Thanks Curtis,
If you don't mind, how would I create a code that looks for a specific sketched symbol "Notes" and move it to a pre-specifiede point, eg 0,0?
Thanks again
PS: My symbol has numerous prompted entries that I don't want changed
