iLogic to build nozzle dimensions
I have an excel table with different nozzle classes and sizes I am interested in (see attached). I am essentially trying to code iLogic to build my nozzles for me and I am a bit of a beginner.
I have so far managed to generate the following code and need a bit of help finishing it;
MultiValue.SetList("Class", "Class 150", "Class 300", "Class 400", "Class 600", "Class 900", "Class 1500", "Class 2500")
If Class = "Class 150" Then
GoExcel.TitleRow = 44
MultiValue.List("Nozzle1") = GoExcel.CellValues("Flanges.xls", "Sheet1", "O45", "O56")
ElseIf Class = "Class 300" Then
GoExcel.TitleRow = 68
MultiValue.List("Nozzle1") = GoExcel.CellValues("Flanges.xls", "Sheet1", "O69", "O80")
ElseIf SIZE = "Class 400" Then
GoExcel.TitleRow = 92
MultiValue.List("Nozzle1") = GoExcel.CellValues("Flanges.xls", "Sheet1", "O93", "O104")
Dim oRow As Integer
Select Case Parameter("Nozzle1")
Case "D": oRow = 45
Case "T": oRow = 46
Case "A": oRow = 47
Case "E": oRow = 48
Case "L": oRow = 49
Case "B": oRow = 50
Case "P": oRow = 51
Case "DB": oRow = 52
Case "N": oRow = 53
Case "DB2": oRow = 54
Case "DRF": oRow = 55
Case "TTF": oRow = 56
End Select
 Any help will be much appreciated.
Thanks.
bradeneuropeArthur
Why not embed the xls file in the part and use this to create your versions of the flange.
This is without I-logic and therefore much easier.
I could show you an example if you want....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
braneneurope,
I have not thought about this to be honest. Any help or example you can share will be a great help.
Thanks.
bradeneuropeArthur
https://www.youtube.com/watch?v=eecgf5o844M
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
You can use the Excel functionality to achieve your needs.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
this is for example a pipe with versions...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
