iLogic to build nozzle dimensions
07:57 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an excel table with different nozzle classes and sizes I am interested in (see attached). I am essentially trying to code iLogic to build my nozzles for me and I am a bit of a beginner.
I have so far managed to generate the following code and need a bit of help finishing it;
MultiValue.SetList("Class", "Class 150", "Class 300", "Class 400", "Class 600", "Class 900", "Class 1500", "Class 2500") If Class = "Class 150" Then GoExcel.TitleRow = 44 MultiValue.List("Nozzle1") = GoExcel.CellValues("Flanges.xls", "Sheet1", "O45", "O56") ElseIf Class = "Class 300" Then GoExcel.TitleRow = 68 MultiValue.List("Nozzle1") = GoExcel.CellValues("Flanges.xls", "Sheet1", "O69", "O80") ElseIf SIZE = "Class 400" Then GoExcel.TitleRow = 92 MultiValue.List("Nozzle1") = GoExcel.CellValues("Flanges.xls", "Sheet1", "O93", "O104") End If Dim oRow As Integer Select Case Parameter("Nozzle1") Case "D": oRow = 45 Case "T": oRow = 46 Case "A": oRow = 47 Case "E": oRow = 48 Case "L": oRow = 49 Case "B": oRow = 50 Case "P": oRow = 51 Case "DB": oRow = 52 Case "N": oRow = 53 Case "DB2": oRow = 54 Case "DRF": oRow = 55 Case "TTF": oRow = 56 End Select
Any help will be much appreciated.
Thanks.
