coordinate system points
 I am trying to attach coordinate points to an assembly file and I am running into problems.  We are creating an operating system for our designs, and I need attach these points to the assembly, label them, and be able to export them with the assembly file.  We are able to do this in Solid Edge, but the dimensions are not being transported with the geometry.  I am hoping that some one here knows if Inventor is capable of something like this.
johnsonshiue
Hi! What particular format you are interested? STEP? I am not aware of an out-of-box solution to do that in Inventor. You may want to take a look at the Inventor App store and see if there is a tool available.
https://apps.autodesk.com/INVNTOR/en/Home/Index
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
It sounds like you are trying to do something fairly complex. If you can document a bit more about your current workflow and what you are trying to achieve that would be helpful.
I think this is similar to what you are trying to accomplish but would need iLogic implemented to achieve:
Unable to export 3d point co-ordinates data to excel
Please select the Accept as Solution button if a post solves your issue or answers your question.
kelly.young
Autodesk Support
Autodesk Support
@Anonymous were you able to get your points to work?
If you can supply an example of what you are trying to accomplish that might help in finding a better workflow.
we did find a way to make it work.  We had to link each point to the extrusion length and there were some stumbling blocks, but I think we will be able to make it work.  Thank you for your concern.
