Select lines by Layer Ilogic
jvalenzuela
Message 1 of 11
jvalenzuela
Hi, is there any method to select lines by layer using ilogic?
Thanks in advance
Replies (10)
Message 2 of 11
bradeneuropeArthur
What lines?
sketches in the model.
Sketches in the drawing.
Sketches in the drawing view.
Model lines the drawing view.
Model sketche lines the drawing view.
Please let me know
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
jvalenzuela
Sorry for the lack of information, the idea is to select only the lines of a certain layer of the model in the drawing view, I searched the forum and the internet but nothing.
Thanks for the quick response
Message 4 of 11
bradeneuropeArthur
What would you like to do with these lines of that specific layer?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 11
jvalenzuela
The idea is selecting all the lines in a certain layer to change it to another, but by means of ilogic
Message 6 of 11
bradeneuropeArthur
Hi.
I am writing something thst seems to work.
You will see this Soon.
Ok?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 11
jvalenzuela
Thanks for Your reply
Message 8 of 11
bradeneuropeArthur
Check This for VBA:
Public Sub l()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim s As Sheet
Set s = b.Sheets.Item(1)
Dim v As DrawingView
Set v = s.DrawingViews.Item(1)
Dim sl As DrawingCurve
Dim sg As DrawingCurveSegment
For Each sl In v.DrawingCurves
For Each sg In sl.Segments
Dim lay As Layer
Set lay = b.StylesManager.Layers.Item("YOUR LAYER NAME TO BE REPLACE WITH")
If sg.Layer.Name = "YOUR LAYER NAME TO BE REPLACE" Then
sg.Layer = lay
Next
Next
End Sub
this For I-logic:
Public Sub Main()
a = ThisApplication
Dim s As Sheet
Dim lay As Layer
sg.Layer = lay
Next
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 11
jvalenzuela
Thanks, I only have add an error handling between two next at the end, but works really fine.
Message 10 of 11
bradeneuropeArthur
That was a good idea to implement that. I do that normally too, but to provide some solutions I never do that to keep it quick and easy to understand.
Thst is also why the declarations are simple dim a as...
Good to hear that it is solved.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 11
dseelbach
Anyone know why this doesn't work on section views?
"Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"
