Message 1 of 11
- Mute
- Permalink
- Report
Hi, is there any method to select lines by layer using ilogic?
Thanks in advance
Thanks in advance
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Sorry for the lack of information, the idea is to select only the lines of a certain layer of the model in the drawing view, I searched the forum and the internet but nothing.
Thanks for the quick response
What would you like to do with these lines of that specific layer?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
The idea is selecting all the lines in a certain layer to change it to another, but by means of ilogic
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thanks for Your reply
Check This for VBA:
Public Sub l()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.ActiveDocument
Dim s As Sheet
Set s = b.Sheets.Item(1)
Dim v As DrawingView
Set v = s.DrawingViews.Item(1)
Dim sl As DrawingCurve
Dim sg As DrawingCurveSegment
For Each sl In v.DrawingCurves
For Each sg In sl.Segments
Dim lay As Layer
Set lay = b.StylesManager.Layers.Item("YOUR LAYER NAME TO BE REPLACE WITH")
If sg.Layer.Name = "YOUR LAYER NAME TO BE REPLACE" Then
sg.Layer = lay
End If
Next
Next
End Sub
this For I-logic:
Public Sub Main() Dim a As Application a = ThisApplication Dim b As DrawingDocument b = a.ActiveDocument Dim s As Sheet s = b.Sheets.Item(1) Dim v As DrawingView v = s.DrawingViews.Item(1) Dim sl As DrawingCurve Dim sg As DrawingCurveSegment For Each sl In v.DrawingCurves For Each sg In sl.Segments Dim lay As Layer lay = b.StylesManager.Layers.Item("YOUR LAYER NAME TO BE REPLACE WITH") If sg.Layer.Name = "YOUR LAYER NAME TO BE REPLACE" Then sg.Layer = lay End If Next Next End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thanks, I only have add an error handling between two next at the end, but works really fine.
That was a good idea to implement that. I do that normally too, but to provide some solutions I never do that to keep it quick and easy to understand.
Thst is also why the declarations are simple dim a as...
Good to hear that it is solved.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Anyone know why this doesn't work on section views?
"Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"
