iLogic - Get model sketch
Message 1 of 11
Greetings everyone,
I found a beautiful video from Curtis, but I can not find the code or command to Get Model Sketch
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/screencast/Main/Detail...
Can anyone help?
Michal
Replies (10)
Message 2 of 11
I modified another macro. It works perfect on part.
But the question is, how can i modifi this macro on flat pattern sketch?
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisDoc.Document
oView = oDrawingDoc.ActiveSheet.DrawingViews(1)
Dim oPart As PartDocument
oPart = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oPartDef As PartComponentDefinition
oPartDef = oPart.ComponentDefinition
Dim oSketch As PlanarSketch
For Each oSketch In oPartDef.Sketches
		Call oView.SetVisibility(oSketch, True)
Next
Message 3 of 11
bradeneuropeArthur
what do you mean with flatpattern sketch?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 11
MechMachineMan
Not necessarily the most robust way, but this should work for you:
Please also note that if you can't expose the sketch through the UI (i.e.; the view is flipped the wrong way), you won't be able to do it through the code - unless you modify the code to handle that situation. Easiest way would be to just flip the view and try the rule again.
Try
Catch
	MsgBox("Base View is not of a part!" & vbLf & vbLf & "Aborting Rule!")
	Exit Sub
End Try
Dim oGenericComponentDefinition As ComponentDefinition
Try
    Dim oSMCD As SheetMetalComponentDefinition
    oSMCD = oPart.ComponentDefinition
	oGenericComponentDefinition = oSMCD.FlatPattern
Catch
    oGenericComponentDefinition = oPartDef
End Try
For Each oSketch In oGenericComponentDefinition.Sketches
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 5 of 11
Thank you very much, that's what I was looking for
Message 6 of 11
Vitalla
I have an assembly with parts below it that I need to get their  sketches. I tried to combine two bits of code I've found the one mentioned  and to recursively navigate the assembly to find the sketches.  It seems to run without errors, and through a message box I can verify I have the correct view & correct sketch I want to make visible I am unsure why it is not showing up. Any help would be appreciated, it seems in the video above by Curtis he was managing to make sketches show from an assembly.
Thanks!
Sub Main()
Dim oView As DrawingView
Dim oViews As DrawingViews
Dim oAssm As AssemblyDocument
Dim Occurrences As ComponentOccurrences
Dim oSheets As Sheets
	oSheets = oDrawingDoc.Sheets
	For Each oSheet In oSheets
		oViews = oSheet.DrawingViews
		For Each oView In oViews
			If oView.ReferencedDocumentDescriptor.ReferencedDocumentType = kAssemblyDocumentObject Then
                Dim RefDoc As AssemblyDocument
                	RefDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
                'recurse all components in assembly referenced by view
                Call recurseOccurrences(RefDoc.ComponentDefinition.Occurrences,oView)
            End If
        Next
    Next
End Sub
Sub recurseOccurrences(Occurrences As ComponentOccurrences,oView As DrawingView)'oView As DrawingView
	    Dim Occurrence As ComponentOccurrence
   			For Each Occurrence In Occurrences
        		If Occurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
           		 	'found assembly, find subparts
           			 Call recurseOccurrences(Occurrence.SubOccurrences,oView)
        		ElseIf Occurrence.DefinitionDocumentType = kPartDocumentObject And InStr(LCase(Occurrence.Name), "tf_sk") Then
					If oView.ParentView Is Nothing Then
						Exit Sub
					End If
						Dim oGenericComponentDefinition As PartComponentDefinition
					    	oGenericComponentDefinition = Occurrence.definition
						Dim oSketch As Sketch
							MsgBox( oSketch.Name )
						Next
            	End If
    		Next
End Sub
Message 7 of 11
madstrolle
I have tried all the different codes in this post.
When I use this code, which works fine, I get all sketches from the part.
I have 1 specific sketch that I want to get from the part.
The best solution would be, if i could run the rule and the choose which view i want to call the model sketches. And then get the correct sketch that i'm looking for. Maybe call the sketch by name.
Message 8 of 11
madstrolle
The pictures shows what i mean.
First picture is whitout model sketches.
Second picture is after running the rule, but as you can see all sketches are shown. I only want the one with the red arrow.
Message 9 of 11
MechMachineMan
You should be able to use my previous code but modify to have a Pick
command with a View Filter applied to it.
>From there, you could either have a hard-coded sketch name format that you
use in all dwgs for which one you want exposed, or pop up a list box (or
even a loop of message boxes) to help you pick the proper sketch to show.
Justin K
Message 10 of 11
madstrolle
You are saying all the right things, but unfortunately i'm not a champ at this.
Could you maybe help me, it would be very much appreciated.
Thank you in advance.
Message 11 of 11
MechMachineMan
No one starts out a champ either! Fortunately, with some persistence,
getting working code after you have a general understanding of object
oriented programming isn't too difficult with the availability of close
solutions and API documentation.
I would suggest perusing the autodesk developer documentation (API
documentation) to get more info on the commands and then string things
together.
Would love to help more, but I don't have time to be googling and stringing
things together myself.
Justin K
