ilogic for automating make components option
Message 1 of 12
Can anyone help me in creating iLogic code for automating "Make Components" feature for a sheet metal part which is having more than two solid bodies.
Replies (11)
Message 2 of 12
bradeneuropeArthur
Could you please give some more details.
There is a command available in inventor for that!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
@bradeneuropeArthur,
Yes there is an option of make components in inventor but I want to automate it using iLogic, can you provide few examples about how to automate make components option.
Message 4 of 12
bradeneuropeArthur
What do you exactly want to automate?
  • Only start the command?
  • or the complete handling of assembly creation part creation and location and file name definitions?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 12
I want to automate complete assembly creation with default file location and only file part names as input.
Message 6 of 12
bradeneuropeArthur
This is possible but not easy. Are you familiar with programming?
I need to search for my code next week. Is this soon enough for you.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 12
I am little bit familiar with vb script and as well as iLogics.
It will be good if you can provide the sample code as early as possible, a week time is ok for me.
Lakshmana Kumar
Message 8 of 12
bradeneuropeArthur
With i-logic this is not possible as I know. Because you cannot create application events. What do you suggest to do...
I only can provide you the vb.net code for this. But you need to provide me the add in setup from your side. In vb.net..
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 12
Hello @bradeneuropeArthur,
What do you mean by add in set-up? if you can tell exactly which files you required, I will check with my IT team and provide you the files.
Message 10 of 12
bradeneuropeArthur
if you could already prepare the add in set up in vb.net then I can try to add coding to it.
Because preparing the add in selves is the most of the work I suggest that you prepare this.
So afterwards I can put this as text to the code you need to prepare...
Regards
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 12
I checked with IT team and they told me that If you share the vb code they will create the add-in setup.
Message 12 of 12
bradeneuropeArthur
Shouldn't be minimum input maximum output..
If I need to check the code I need to have an add in for this, so please advise your
IT to be a little more willing to help you and your organisation with providing the add in.
I am not going to prepare this add in because it is always a little different for each add in regarding settings etc and is too time consuming. The code only would not be the problem I assume.
An add in will never contain confidential information, so I don't see the problem.
Please let me know what your IT is willing to do for you.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
