Error in Rule
Error in Rule
Error in Rule
I am trying to change the position of some boxes within a drawing border depending on whether the text inside them is blank or populated, however I am getting an error below.
Error in rule: Revision Table, in document: APPTEST4.idw
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
here is my code, can anyone help please??
SyntaxEditor Code Snippet
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oTitleBlockDef As TitleBlockDefinition
oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item("A-B")
Dim oSketch As DrawingSketch
oTitleBlockDef.Edit(oSketch)
Dim oDim As DimensionConstraint
'find d0
For Each oDim In oSketch.DimensionConstraints
	If oDim.Parameter.Name = "d171" Then
		Exit For
Next
If iProperties.Value("Custom", "NEF3-2 ECO") = "" And
iProperties.Value("Custom", "ECO") = "" Then
oDim.Parameter.Value = 7.125 And
ThisDrawing.Document.StylesManager.Layers("NEF3 1").Visible = False
Else If iProperties.Value("Custom", "NEF3-2 ECO") IsNot "" And
iProperties.Value("Custom", "ECO") IsNot "" Then
oDim.Parameter.Value = 11.875 And
ThatWorksForMe
do you have a titleblock called "A-B"?
Thi part creates the error.
PDM/CAD Administrator
Using Inventor/Vault 2024.3
Thanks, I have changed "A-B" to the correct Title block, however, now the rule just opens that title block and stops. The feature I am trying to alter is within a Borders definition.
ThatWorksForMe
I tried this code and it works for me.
'find d0
	If oDim.Parameter.Name = "d0" Then
		Exit For
Next
If iProperties.Value("Custom", "NEF3-2 ECO") = "" And iProperties.Value("Custom", "ECO") = "" Then
Else If iProperties.Value("Custom", "NEF3-2 ECO") IsNot "" And iProperties.Value("Custom", "ECO") IsNot "" Then
oTitleBlockDef.ExitEdit
