how to turn off prompt "Save changes to *****.ivb?" from VBA
liminma8458
liminma8458
hi,
I have some add-ins from VB.NET and they have NO association with VBA in Inventor. But everytime after I run the add-ins and before I close Inventor, a prompt "Save changes to *****.ivb?" shows up, indicating I may change something in VBA code. A sample prompt is included in attached file.
My question is why this prompt shows up and how to silent it or turn it off automatically with API or whatever method?
Limin
Limin
Inventor pro 2023 64 bit update 5.3; Windows 11 pro 64 bit version 24H2; Office 2013 64 bit
Download iCable in App Store to Create Cables Easily
NachoShaw
Hi
to confirm if your vb.net is in fact, updating the ivb you could rename or copy / move the ivb to a different location then run the addin again. If the addin looks for the ivb, then you will know that it is changing something because it wont find and it will throw an error
Cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
liminma8458
Thanks Nacho!
Although I have not try the way you recommended yet, I believe it will be very practical.
I just got a way to work out the problem. In the dialog of choosing Default VBA project in Application Options, as shown below, check the box "Check as read-only", the "Save..." prompt will not show up after I run my VB.NET program.
Limin
cadadmin
Thank you for this message. I have tried this and on some of the machines it works and others it does not. Anyone else know what may be causing this? Or alternative solutions to eliminate the annoying message?
bradeneuropeArthur
Could you please make a screenshot of the references in your add in?
and post it.
To see what has been referenced.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
