Message 1 of 1
API Constraining to Work features
06:03 AM
As part of an AddIn am writing I want to place two constraints on a newly inserted content center part. I am trying to place a flush and a mate constraint based upon selecting two faces from the existing item and using the YZ Plane and X Axis of the newly inserted part. but am now completley stuck. No matter what I try, the line of code to create the constraints keep throwing up the incorrect parameter error:
[The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))]
I can make the code work if I manually select both surfaces for each constraint, but not otherwise.
Dim ADoc As AssemblyDocument = InvApp.ActiveDocument Dim Invpart1 As ComponentOccurrence = InvApp.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select Part") Dim Invpart2 As ComponentOccurrence If Invpart1 Is Nothing Then Exit Sub Dim oPlane1 As Face = InvApp.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select First Face") Dim Hole1 As Face = InvApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceCylindricalFilter, "Select Hole") 'Commented out as seems to make no difference. 'Dim oPLane1Proxy As FaceProxy = Nothing 'Invpart1.CreateGeometryProxy(oPlane1, CType(oPLane1Proxy, FaceProxy)) 'Dim Hole1Proxy As FaceProxy = Nothing 'Invpart1.CreateGeometryProxy(Hole1, CType(Hole1Proxy, FaceProxy))
'part that added new item ommitted for clarity/size
Invpart2 = asmDef.Occurrences.Add(memberFilename, transMatrix) Dim oPlane2 As WorkPlane = Invpart2.Definition.workplanes.item(2) Dim oAxis1 As WorkAxis = Invpart2.Definition.workaxes.item(1) Dim oPLane2Proxy As WorkPlaneProxy = Nothing Dim oAxis1Proxy As WorkAxisProxy = Nothing 'Invpart2.CreateGeometryProxy(oPlane2, oPLane2Proxy) Invpart2.CreateGeometryProxy(oPlane2, CType(oPLane2Proxy, WorkPlaneProxy)) Invpart2.CreateGeometryProxy(oAxis1, CType(oAxis1Proxy, WorkAxisProxy)) If Invpart2.Grounded Then Invpart2.Grounded = False
'The code runs fine down to here:
'asmDef.Constraints.AddMateConstraint(Hole1, oAxis1Proxy, 0) asmDef.Constraints.AddFlushConstraint(oPlane1, oPLane2Proxy, 0)
If someone can tell me what I'm missing here.
As always, any help is greatly appreciated.
