ilogic code crashes when autorun but not manually?!
I've developed some iLogic to do some tasks. When suppressed and run manually it works fine. However when I update parameters I want it to autorun, which it does, it executes the entire code and then crashes Inventor.
I've tried putting the code within a transcations and without a transaction. Also removing any doc updates. Am I missing something glaringly obvious here?
MegaJerk
It's next to impossible to solve a possible code related problem without having seen the code in question.
Please post your code, and give any context we might need to understand the usage scenario.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
*cough* it's quite messy code at the moment, but as I say, it works when manually run so not sure why it doesn't when autorun. The function of the script is to delete certain fetaures and rebuild them through extrusions and combines each time it updates with new parameters. When autorun the code runs fully and gets to the end of the main sub completing the transaction and crashes out.
Sub Main extrude_and_mill
	Dim oTrans As Transaction
	oTrans = ThisApplication.TransactionManager.StartTransaction( ThisApplication.ActiveDocument, "extrude all")
	Dim part_doc As PartDocument
	part_doc = ThisApplication.ActiveDocument
	delete_del(part_doc)
	Dim sketches As PlanarSketches = ThisApplication.ActiveEditDocument.ComponentDefinition.Sketches
	Dim n As Double = 0
	For Each oSketch In sketches
		'make visible
		oSketch.Visible = True
		'MsgBox(oSketch.Visible())
		'make invisible if not extruding
		If col < 2 Then
			If oSketch.Name = "virt_bot"
				oSketch.Visible = False
			Else
		'extrude if still turned on
		If oSketch.Name = "base" Then
			'do nothing
		Else
			If oSketch.Visible() = True Then
				If n = 0 Then
					'MsgBox("newsolid")
					extrude(oSketch, part_doc, True, 1.2, True)
					rename_solids("tool")
					n = n + 1
				Else
					'MsgBox("joining")
	Next
	lastSketch = sketches("base")
	extrude(lastSketch, part_doc, True, 1.8 + off/10, False)
	rename_solids("base")
	combine_features()
	oTrans.End
	'iLogicVb.UpdateWhenDone = True
	InventorVb.DocumentUpdate()
End Sub
Sub delete_del(part_doc)
	Dim comp_def As ComponentDefinition
	comp_def = part_doc.ComponentDefinition
	For Each feat In comp_def.Features
		If feat.Name.contains("del")
			feat.delete(True, True, True)
	Next
End Sub
Sub combine_features()
	Dim bodies As SurfaceBodies = ThisApplication.ActiveEditDocument.ComponentDefinition.SurfaceBodies
	Dim toolbodies As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
	Dim basebody As SurfaceBody
	For Each body In bodies
		If body.Name.contains("tool")
			'MsgBox("defined tool")
			toolbodies.add(body)
		Else If body.Name.contains("base")
			'MsgBox("defined base")
			basebody = body
	Next
	'CombineFeatures.Add( BaseBody As SurfaceBody, ToolBodies As ObjectCollection, Operation As PartFeatureOperationEnum, [KeepToolBodies] As Boolean ) As CombineFeature
	Dim CombineFeatures As CombineFeatures = ThisApplication.ActiveEditDocument.ComponentDefinition.Features.CombineFeatures
	'MsgBox(CombineFeatures.count())
	Dim booloperation As PartFeatureOperationEnum
	booloperation = kCutOperation
	Dim mill As CombineFeature
	mill = CombineFeatures.Add(basebody, toolbodies, booloperation)
	mill.Name = "MILL_del"
End Sub
Sub rename_solids(toolorbody)
		If body.Name.contains("tool") Or body.Name.contains("base")
			'do nothing
		Else
			body.Name = body.Name & "-" & toolorbody
	Next
End Sub
Sub extrude(oSketch, oPartDoc, newSolid, dist, positive)
' Create a profile that can be used for extrusion
'Dim oProfile As Profile
oProfile = oSketch.Profiles.AddForSolid
Dim n As Integer = 0
'MsgBox("profiles " & oSketch.Profiles.count())
For Each oProfile In oSketch.Profiles
	n = n + 1
	Dim oCompdef As ComponentDefinition
	oCompdef = oPartDoc.ComponentDefinition
	'Determine the extrusion direction from the radiobuttons
	Dim extrusiondirection As DirectionEnum
	If positive = True Then
		extrusiondirection = kPositiveExtentDirection
	Else
		extrusiondirection = kNegativeExtentDirection
	'Determine the boolean operation from the radiobuttons
	'Read the extrusion height from the text box and convert to appropriate units
	Dim extrusionheight As Double
	extrusionheight = dist
	' Create an extrusion without draft angle and based on an extrusion distance
	Dim oExtrude1 As ExtrudeFeature
	If newSolid = True Then
		booloperation = kNewBodyOperation
	Else
		'oExtrude1 = oCompdef.Features.ExtrudeFeatures.AddByDistanceExtent( oProfile, extrusionheight, extrusiondirection, kJoinOperation)
		booloperation = kJoinOperation
	oExtrude1 = oCompdef.Features.ExtrudeFeatures.AddByDistanceExtent( oProfile, extrusionheight, extrusiondirection, booloperation)
	oExtrude1.Name = "FEATURES_del_" & oSketch.Name & n
Next
End Sub
MegaJerk
Is there a test part that you have that you can also share with us for easy testing?
GitHub
Hey, yeh see atached.
