Shorten Bend lines on DXF export
Hi there. I was wondering if it's possible to shorten Bend lines on Flat Pattern DXF export? As standard Inventor will export bend lines between two outer contours, but can you create a post process that will trim 5mm off of each end of the bend line? Best regards Yannick Nielsen
wayne.brill
Hi Yannick,
If you believe this is a problem with Inventor creating a DXF from a flat pattern please post it on the Inventor Idea station:
http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232/tab/most-recent
The Inventor API does not have anything that would change a DXF file after it was created.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
w.pepping
Hello Yannick,
At the moment I am working to add this function to my app Publish Tool.
Adding properties as text is already possible in the DXF post-process.
Adding bend information near the bend lines in the DXF will be available too in the near future.
Regards, Wim Pepping
Get control of your sheet metal files.
Download the app from matprop.com
That sounds really cool - I will be looking forward to see that! 🙂
