How to open an assembly in readonly using C#
oransen
Message 1 of 9
oransen
I'm able to open an assembly in C#, but I'd like to be able to open it in read only.
Is that possible? I've looked at the OpenWithOptions, which has visibility and NameValue list, but I can't see a read only option...is there one?
Replies (8)
Message 2 of 9
bradeneuropeArthur
Dim fio As New System.IO.FileInfo(fullfilename)
        fio.IsReadOnly = True
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
oransen
Hello, maybe I've missed something but you've told me how to open a file (not an assembly) in VB (not in C#).
Have I missed anything?
Message 4 of 9
bradeneuropeArthur
No I did not open the file.
I created the read-only flag for the specific file.
After this you can open the file as usual.
The file will open read-only.
For C#:
 // Sets the read-only value of a file.
        public static void SetFileReadAccess(string FileName, bool SetReadOnly)
            // Create a new FileInfo object.
            FileInfo fInfo = new FileInfo(FileName);
            // Set the IsReadOnly property.
            fInfo.IsReadOnly = SetReadOnly;
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 9
oransen
So... I had missed something! Thanks for that, but is that the only way? It means  I have to reset the raw file properties at the end of the operation back to whatever they were...
Message 6 of 9
bradeneuropeArthur
only possibility is to open the file deferred!
This could also be an option.
But you asked for read-only specific.
Why do you like to open a file read-only?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 9
oransen
So neither my program nor my users can interfere with the assembly while my the program is running.
As far as the users are concerned I've realized that all I have to do is set it to be open invisible.
As far as my program is concerned I'll just have to be careful!
Thanks!
Owen
Message 8 of 9
JamieVJohnson2
If you turn defer updates on, Inventor blocks all kinds of editability, to the in-memory data.  But the file itself stays as is, so that is what I use for read-only processing, where I only want to read from the file, and not modify it.
Here is my complex open file tool that I use with many different scenarios (vb.net written in vs 2015-2019):
   Public Function OpenInventorFile(fileinfo As SIO.FileInfo, Optional Deferred As Boolean = False, Optional Hidden As Boolean = False, ByRef Optional FileOpened As Boolean = False) As Inventor.Document
        If fileinfo.Exists = False Then Return Nothing
        Dim invDoc As Inventor.Document = Nothing
        Dim invApp As Inventor.Application = TTSInventorTools.GetInventorApplication()
        Try
            If invApp IsNot Nothing Then
                'open document
                Try 'find open document
                    'invDoc = invApp.Documents.ItemByName(fileinfo.FullName)
                    For Each doc As Inventor.Document In invApp.Documents
                        If doc.FullFileName = fileinfo.FullName Then
                            invDoc = doc
                            Exit For
                        End If
                    Next
                    'invDoc.Save()
                Catch ex As Exception
                    'open file by name
                End Try
                If invDoc Is Nothing OrElse Hidden = False Then
                    If Deferred = True Then
                        Dim docOpenOptions As NameValueMap
                        docOpenOptions = invApp.TransientObjects.CreateNameValueMap
                        docOpenOptions.Add("SkipAllUnresolvedFiles", True)
                        If fileinfo.Extension = ".idw" Then docOpenOptions.Add("DeferUpdates", True)
                        Dim silentPrev As Boolean = invApp.SilentOperation
                        invApp.SilentOperation = True
                        If Hidden = True Then
                            invDoc = invApp.Documents.OpenWithOptions(fileinfo.FullName, docOpenOptions, False)
                            FileOpened = True
                        Else
                            invDoc = invApp.Documents.OpenWithOptions(fileinfo.FullName, docOpenOptions, True)
                            FileOpened = True
                        End If
                        invApp.SilentOperation = silentPrev
                    Else
                            FileOpened = True
                        Else
                            FileOpened = True
                        End If
                    End If
                End If
                If invDoc Is Nothing Then
                    FileOpened = False
                    Throw New Exception("Attempt to open file failed:" & fileinfo.FullName)
                End If
            End If
            Dim eh As New ErrorHandler(New System.Exception("Can not open file:" & fileinfo.FullName & vbCr & ex.Message))
            eh.HandleIt()
        End Try
        Return invDoc
    End Function
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 9 of 9
oransen
Many thanks for that. 🙂
