02:10 AM
I've looked through the forums but can't seem to find the right code.
For example, I have a boolean parameter called Solid and a solid body called Solid_Body
I would like to be able to do something like feature/component suppression if the boolean value changes, for example:
If Solid = True then
Solid_Body= 1
else
Solid_Body= 0
end if
What would be the code to do something like this?
Thank you
