Adding a custom radial marking menu
basnederveen
basnederveen
Hi everyone,
I've been struggling with customizing a marking menu. I do not want to add some button to an existing marking menu but create a custom marking menu when I right click a certain object.
The object is now a sketchedsymbol, when I get the linearMarkingMenu my code starts and i want to add a radial menu with some custom commands. The problem is that the radial menu is not showing at all for this selection.
I use the following code for testing:
' Declare the event objects
Private WithEvents oUserInputEvents As UserInputEvents
' Create a flag for when selecting is started or finished
Private bSelecting As Boolean
' Initialize the class to start watching events
Sub Init()
    ' Create an InteractionEvents object.
    Set oUserInputEvents = ThisApplication.CommandManager.UserInputEvents
End Sub
Private Sub oUserInputEvents_OnPreSelect(PreSelectEntity As Object, DoHighlight As Boolean, MorePreSelectEntities As ObjectCollection, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
    ' Check if the preselected entity is a sketchsymbol
    If TypeOf PreSelectEntity Is SketchedSymbol Then
             bSelecting = True
End Sub
Private Sub oUserInputEvents_OnLinearMarkingMenu(ByVal SelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal LinearMenu As CommandControls, ByVal AdditionalInfo As NameValueMap)
    If bSelecting Then
        Call Create_MarkingMenu(SelectedEntities.Item(1))
End Sub
Private Sub Create_MarkingMenu(SelectedEntity As Object)
    Dim rrm As RadialMarkingMenu
    Set rrm = ThisApplication.UserInterfaceManager.ActiveEnvironment.GetRadialMarkingMenu(ObjectTypeEnum.kSketchedSymbolObject)
    ' Define some test buttons
    Dim oDef1 As ButtonDefinition
    Set oDef1 = ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomAllCmd")
    Dim oDef2 As ButtonDefinition
    Set oDef2 = ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd")
    Set rrm.NorthControl = oDef1
    Set rrm.SouthControl = oDef2
End Sub
I've tried
ThisApplication.UserInterfaceManager.ActiveEnvironment.GetRadialMarkingMenu(), with this I do get a menu, so apparently it is present it is just not showing. How do I show this menu?
and
ThisApplication.UserInterfaceManager.ActiveEnvironment.RadialMarkingMenus.Add(), with this I've apparently added a new 'Sub-environment' to the customize marking menu, also great. How do I get this menu to show up for example after clicking a button or a different event? Or how do I add this to a linear markingmenu which does not have a radial menu?
Curtis_Waguespack
I know this is an old thread, but I was just working on this as well.
Here is an example Visual Studio project, working with Inventor 2023, that provides a working example of this.
This example creates 2 custom radial menus. One general one that displays on the radial menu when it displays, and another that only shows when a parts lists is right clicked on ( parts lists do not have any radial menu out of the box)
When clicking on a parts list you see 2 custom sub menus
The contents of the General Hello Tools submenu has the 3 buttons
The contents of the Parts List Hello Tools submenu has the 3 buttons
When clicking in empty space on a drawing sheet you see this, you get only the General Hello Tools in the custom submenu as shown:
I hope this helps.
Curtis
        Private Sub OnSelectEvent() Handles UserInputEvents.OnSelect
            Dim oApp As Inventor.Application = g_inventorApplication
            Dim oDoc As Document = oApp.ActiveDocument
            Dim oSelectSet As SelectSet = oDoc.SelectSet
            Dim RadialMenu As RadialMarkingMenu
            Dim subMenu As RadialMarkingMenu
            Dim obj As Object = oSelectSet.Item(1)
            'if a parts list is selected
            If obj.type = ObjectTypeEnum.kPartsListObject Then
                RadialMenu = g_inventorApplication.UserInterfaceManager.ActiveEnvironment.GetRadialMarkingMenu(obj.type)
                subMenu = RadialMenu.CreateRadialSubMenu("Parts List Hello Tools")
                subMenu.EastControl = Hello_World_Button4
                subMenu.SoutheastControl = Hello_World_Button5
                subMenu.SouthControl = Hello_World_Button6
                RadialMenu.EastControl = subMenu 'right of radial menu
        End Sub
